I have a Bose Acoustimass 10 version 4 Home Theatre system. It is hooked up via HDMI to my Onkyo Receiver. Also connected to my Onkyo receiver is my Sony Blu Ray player. These units are plugged into a good surge protector. There is a constant buzzing sound emanating from the module/subwoofer that is present whether or not I'm watching Comcast cable or a Blu Ray or DVD. The buzz goes away if the volume is mute or if the receiver is off. I have tried a different wall outlet but that didn't work... Any suggestions? Please... It driving me crazy! Thx Jay
You are only given one answer from our Expert Ray with the brief answer 'No sorry'.
This is your VSX
REAR TERMINALS
HDMI 4 in
HDMI 1 out
AV (Composite) 2 in
Audio 1 in (assignable)
Digital Coaxial 1 in (assignable)
Digital Optical 1 in (assignable)
Monitor Composite 1 out
Preout 0.1ch (SW)
Speaker 5 ch out (FRONT, CENTER,
SURROUND)
and this is your Bose. Find the manuals for both and read them. connecting them
A: Glancing at the specifications of the Bose Acoustimass 10, the system is stated to be compatible with A/V receivers and amplifiers rated from 10-200 watts per channel, and from 4 ohms to 8 ohms. Aug 17, 2014
Hey Any chance you have the Acoustimass 15 II or III? The first Acoustimass 15 has a switch. The II and II models turn off and on when it receives a signal from the source you are using. Amplifier, ect. All you need to do is make sure everything hooked up correctly and plug it in.
You should have the HDMI plugged into the Home theater unit. The theater unit then is attached to the TV using the HDMI out.
The home theater unit passes the HDMI through to the TV while playing the audio for you.
You will likely need to select the correct source on your RT2910.
Here is a link to the manual.
http://www.1800customersupport.com/productdocuments/RT2910_RCA.pdf
See the section entitled "Connecting to HDMI Components" for an illustration of what I have described above.
There's a pretty decent write up for this speaker system on CNet. The "Speaker System" section calls for an amplifier capable of 10 - 150 watts RMS.
Bose maintains a library on their products as well. You can download FAQs, Manuals and Product Information easily. On the accessories tab, Bose lists an Onkyo receiver for $350 that will work very well with this speaker system. Of course, any quality modern stereo receiver or amplifier with power in this range 10 - 150 watts should provide good results, but better amps will be in the 75 watts and greater range.
If you have the money to plunk down for a Bose Acoustimass home theater speaker system, I'm sure you will be quite pleased. Of course, as you indicated, appropriate placement of the speakers is important. Still, I'm sure you will find that a properly placed Bose Acoustimass speaker system will fill your room with high quality sound, substantially better than Onkyo's stock speakers placed equally well.
I own a Technics home theater system, which I initially purchased to use in my family room. Yet, when I listened to a Bose Lifestyle system (powered by Bose Acoustimass speakers), I could have nothing less. The Bose system went in the family room, where everyone could enjoy it. I put the Technics system in the bedroom, where it is rarely used.
The entire 5.1 amplification system, in the Bose Lifestyle 35, is actually part of the Bose Acoustimass (subwoofer) module. The RJ-45 (network type) connector passes a low-voltage signal from the console to the Acoustimass module. If you were to hack the connection, and plug the speaker outputs of a 5.1 receiver to the RJ-45 socket on the Acoustimass module, you would blow the amplifier.
If you are really itching to replace the Bose Lifestyle 35 console with a regular 5.1 receiver, I strongly suggest you sell your Bose system, and purchase a Bose speaker system, such as the Acoustimass 10 Home Theater Speaker System, which is made for use with a standard 5.1 surround sound receiver.
Well, first of all this speaker system is designed to give you a subwoofer where you do not have a sub-woofer output on your receiver/amp. However, that is not the case with the Onkyo. The way I would set it up (only because of the speakers you have) according to the Acoustimass Manual. You take the left and Right "Speaker" outputs to the Left and Right input on the Acoustimass and the speakers crossover does the rest. The Onkyo is designed to have a powered subwoofer so in this format you would just tell the receiver to turn off the sub channel which would tell the Onkyo to send the low end to LR. That should do it.
Hope this may help but you will disappointed. as heard from some pro, your amp will blow up the bose cube if direct connected to them, they are powering down your output to fit their tiny speaker. My understanding was you have to hook up everything to the bose module. They don't like to play with others.
Try this:
Go into the menu settings by pressing "Receiver" --> "6-Video" --> "HDMI Audio" select "Amp," not "Amp+TV"
Yeah, it makes total sense to have a very important audio setting in the video menu.
