Hi, sorry to bother you, but I am having a very similar problem with my monitor, it just goes black, although if I look very very close I can see that the image is there, its just to dark to see it, every time I press the source button and it gets to digital the image comes bright and normal, but a second later its dark again.
If you can still faintly see data on your screen, it will be a faulty backlight in the panel most likely.
LCD panels have fluorescent tubes in them that provide the light needed to see the data. If one of these goes faulty, the circuit that drives it will turn off ALL the backlights, giving you a black screen.
Note: a faulty circuit that drives the backlights will often give the same apparent fault.
You will need to take the monitor in for repair.
SOURCE: syncmaster 226bw goes black
i think u have a problem with ur display,please contact ur service centre immediately to fix it.
I have the same problem. Have 2 of the Samsung SyncMaster 214T LCD monitors and both have same exact problem. If I leave the screen on it will go black and will sometimes come back on if I turn monitor on/off. I have tried a Dell monitor to ensure not the Video card and Dell works fine. Something is wrong with these Samsung monitors. I would open up for repair if anyone has a solution otherwise these are headed for the junk heap. Shame....these were expensive monitors too.
my screen goes mostly black. it just started doing this after about 8 months of operation.
same prob here!
after 8 months it just stopped working
all i see now is a black screen with that pop up that says
check signal cable
and thinks i plugged in a analog cable or somethign:S
im going to call samsung today
cheap suckers
