The inside of the door has screws that will come off to gain access to the mounting holes of the ovens outside door. Clean the entire door area so the job will be easier to battle with
Remove the screws and the door will seperate and you can reinstall the door handle.. mm most whirl ovens have lift off doors this may make it easy to work on .. mm hope this helps if more help is needed i need your model # off the tag on your oven .. mm feed back pls .
if the handle is broken let me know . but need model # for look up .. mm
looking your model the door doesnot have to come off to service . youu do have to take apart to replace the screws .. go to www apdepot.com and put in your brand an model # this will give you a good brake down or this door . there are many parts to the door . so the diag will help .. mm
Model # is RBS305PRSOO DOOR IS APART CANNOT GET TO SCREWS THREW BACK OF DOOR
DO I NEED TO TAKE THE DOOR APART
CANNOT GET THE DOOR OFF
The handle is not broken. RBS305PRSOO. If it's easier, call 330 354-8404. Thanks.
Well we just took the whole door apart for nothing
