Acer Aspire One  PC Notebook Logo
Posted on Nov 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I turn my netbook on it starts but goes straight to black screen and nothing happens, I went to safe mode but whenever I press Entre it reboots and goes to black screen again, I have no cd-rom ... so I cannot really repair windows. I tried ctrl+alt+del but makes the netbook starts and to black screen again. I tried to take the batterie off ... nothing. The last thing I did was when I received a small window on the screen saying you computer is at risk press yes to download the antivirus, It annoyed me coz it kept popping up and once I pressed yes that is it ... I have a problem now I do not know what to do please help.
Jitha GJ
Level 2:
Novelist:
  • Acer Expert 239 Answers
  • Posted on Nov 26, 2010
Jitha GJ
Acer Expert
Level 2:
Novelist:
Answers
239
Questions
0
Helped
50284
Points
371
It appears that the computer is infected with virus and may need full system recovery. You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key
& keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on
the computer.
You can also create a set to Recovery disk from the recovery partition, to do so
Start Menu> All Programs> Acer erecovery management> Click Create Factory Default Disk, if you receive any error code or unable to burn the disk, please contact Acer Technical
support at 1 800 816 2237 and order for an Recovery Disk.
Thanks and regards,
Jitha
I have a panasonic tough book. I was trying to remote connect to my work server. I was following instructions to fix my setup to connect per our IT department. I went to programs, accessories and remo
Will it come on in safe mode? Reboot the system, continually press F8 to see if it will come on in safe mode. If it does let it completely finish then try rebooting again to see what happens.
Sylvania netbook synet07526 - - - cant remember my password. how can i reset the system? have tried holding down the reset button multiple seconds but the reboot does nothing but come to the password...
Resetting password & user name on Windows: b>*Start your computer
*Keep pressing "F8" as the computer starts.
*This will enter the computer in Safe Mode.
*(When the window "Advanced Boot Options" opens, choose "SafeMode" with arrow key and confirmby pressing the Enter key, then computer enters Safe Mode.
*Once you are in the Safe mode Click "Administrator" on the Windowslogin screen.
*Take note that you have set the Administrator password before, you need toinput the changed password instead of leaving "Password" field blank.
*Then click Start > Control Panel > User Accounts > Select the accountthat is locked and change the password.
**Restart computer and login into the account you just created using your newpassword.
I have a Toshiba NB255-N250. When it boots up it starts loading windows and then I get a black screen with an arrow cursor. For a few seconds a blue circle moves next to the arrow then it stops and...
It seems something flooding your startup.
Try this method:
1. Reboot your computer.
2. After bios logo, press F8 to enter safe mode.
3. Choose safe mode the (first menu).
4. After entering desktop menu go to System Restore and restore your computer to the best condition (date).
Hope this will answer your problem.
7helpful
4answers
Netbook Wont Turn On!!!
Restart your computer and keep pressing F8 and choose safe mode from the menu
once you enter safe mode,click on start->settings->control panel->system and then device manager
and under display adaptors,disable your display card and then restart it again and see if it works
Monitor went black after changing resolution
Reboot you computer and spam F8 until you get the option to boot in safe mode then choose VGA safe mode or safe mode with network is fine also and change the resolution back
1helpful
Blank/Black Screen Asus PC 4G
When you first turn on the computer, start tapping the F8 key to bring up the safe mode screen. You have a very short window in which to press the F8 key before XP loads, so it is possible to miss it. If this happens, just restart it and try it again. Once you are on the safe mode screen, select the enable VGA mode. This will boot your computer to a default 640 x 480 resolution so you can change it back to normal.
Thanks and please don't forget to give this solution a fixya rating.
1helpful
Cannot start Sony VAIO PCG-5J2L /Goes to black screen only
During start-up the computer will go to a black screen for awhile and then the pointer arrow will show alone, and then the system will come up.
If you think it's a hibernation problem, pull the ac plug and battery out for about 1 hour and then plug back in.
If this didn't work, then try the F8 Key and choose "Last Know Good Configuration".
Cant get to reboot in safe mode
Trying pressing F8 about every 5 seconds from the you turn the computer on any faster and this will give a stuck key error. This should put you in safe mode.
Windows will not start
start your system in safe mode...
and run the scan pressing instant scan...
Here is the link
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
