The internal memory is the memory built into the camera, not the memory you put in with a memory card. This internal memory is rather small. If it is completely full, it will stop your camera working even with an empty memory card.
Take the card out of the camera, and delete some of the photos on the internal memory before you put it back in.
SOURCE: Camera keeps saying internal memory is full, even after putting a
Your internal memory is separate from your memory card. Think of it as two folders, the internal memory cannot be removed, and the memory card is one you can take with you. You can put new memory cards in it all day, the internal memory will still have pictures in it. You may wish to consider copying all internal memory to the memory card. To do this, make sure your camera has a memory card in it. View pictures on your internal memory, then from the menu option select 'copy all images to external memory.' In doing this, all of your photos will be moved, you can then clean out your internal memory by deleting everything/formatting it. :)
SOURCE: Just put 2gb sd card
on a kodak you can also copy your internal photos to card-go to menu and find menu highlight that says storage or something like that and change setting to use card first-when the camera has a card in it it will usuallt default to card first
SOURCE: Internal Memory Full??
The Internal memory and SD card are different beasts. There is a certain value that alows pics to be taken without a memory card in situe. It is this part that is saying the memory is full Use settings to clear internal meory of photos or files being held. If this oersists even after yoiu have emptied the memory you will need to take it to a Kodak outlet
SOURCE: I put a new memory card in the camera and it says
You need to eliminate the pics from the internal memory. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, insert your card and do the "format" thing again for the card. Everything should be normal now.
