I have Lifefitness 95T the main monitor shows me this massage (Unit Immobilized by Manager) .And the machine does not work .Can I fix the problem by myself or I need an export.
When necessary to immobilize the treadmill, set display to read SELECT A WORKOUT. (Press the STOP Key twice if not already there). Then hold down the SPEED DOWN Key and press the STOP Key. The treadmill now displays IMMOBILIZED. In this state, the treadmill cannot be operated. The main motor and incline are disabled. The treadmill will remain in this state across resets, power cycles, etc. To restore normal operation, repeat the same key sequence: hold down the SPEED DOWN Key and press the STOP Key. The treadmill will display SELECT A WORKOUT again.
I would suggest removing your heart rate grips and inspecting the contact leads for rust or any other corrosion. This is very commonly an issue and can be resolved by either cleaning the contacts or simply replacing the parts. Using the following link, and your serial number, you should be able to find the contact grips if you end up needing them.
This sounds like a motor control board issue. In my experience I have seen it either speed up when it is supposed to slow down or you will get a pulsating or lunging type action in the running belt. There are companies available that can test and repair said board for a fraction of the price. You might check with Carolina Technical Services LifeFitness motor controller repair
To Get to the manager and check for disabled items. To enter the Systems Options Menu: 1. Press SELECT WORKOUT. 2. Touch the Life Fitness logo in the upper right hand corner of the screen three consecutive times go to configuration Configuration Allows authorized personnel to access all configurable settings of the unit. Configurations which should only be changed by qualified technicians are password protected. Manager Vivo/Network Manufacturer , Create Your Own Media Center , Clock Custom Workouts Touch Screen Configuration Export / Import Settings The console manual will show you all the default values . https://www.lftechsupport.com/c/document_library/get_file?p_l_id=27605&folderId=483177&name=DLFE-28306.pdf
I believe the tread has been locked out (safety feature important for clubs) - you can call lifefitness and they will give you the key sequence to unlock it
This mean that you unit is not equiped with a receiver inside the treadmill. Some models that was an option. Polar is the only brand that works with Lifefitness. You may have a bad upper display board. You can buy a replacement for a small amount of money.
