Nakamichi AV-7 Receiver Logo
Posted on Jun 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
NO SOUND IN AV 1 SET GETS ON BUT NO SOUND
Jayson Brollini
Level 2:
Sergeant:
  • Expert 241 Answers
  • Posted on Aug 28, 2008
Jayson Brollini
Expert
Level 2:
Sergeant:
Answers
241
Questions
11
Helped
63366
Points
551
HI
>check the settings on the stereo and see if you have the correct setup: AV 1 ( DTS, Auto, Analog)
If you are using the standard RCA cable (red/White) = Analog
or try the Auto if you are not sure.
I hope this can help
Thanks
1helpful
2answers
I wish to connect the Sinotec 55 to my Phillips soundbar , which inly had one set of Rca inputs , which are bringing sound to it from the Dvd player ?
55 is not the model, 5.1 sound but I will take your word on jacks
many cheap TVs have only HDMI , no RCA jacks Video/audio in/.
and I see yours has the 3.5mm phone jack style AV in
well that really is Audio left/right sound, TRS
so all you do is buy a RCA 2 CABLE audio, TO 3.5MM ADAPTER
AND USE THAT.
pick the gender of both ends. 2 cable to 1, not 3to 1
https://www.fixya.com/answer/answerpageslideview.aspx?thid=29885463&ctg=465&brd=298
tip
Adding your own music to Super Smash Bros. Brawl
To play your own music on super smash bros brawl, follow these 10 simple steps, but first, this is what you need: an audio source (ipod mp3 player, etc.), SSBB, a wii, and AV cables (red, white, yellow on one side and silver on the other that can be inserted into your audio source
1 take an audio source (mp3 player, ipod, etc.) and plug in the AV cables.
2 Start super smash bros. brawl.
3 go to options
4 go to sound
5 set music off and sound max
6 set up your game normally
7 move your cursor over the stage you want to play.
8 remove the RED cable of your wii and insert the RED AV cable connected to your audio source
9 Chose your song
10 start your game!
2helpful
I cant get any sound I did the trouble shooting
Changing the Audio Output
To switch audio output from the internal TV speakers to a connected external sound system or headphones:
Press 1. MORE.
Press 2. 9 (AUDIO).
Press 3. until the Speakers option is displayed. The Speakers option will display only if an A/V receiver connection has been detected.
Press 4. to switch between TV and either AV Receiver or Headphones.
Check if the MUTE key is on.
• The TV's "Listen to:" setting may be set to SAP (analog program from the ANT input) but no SAP is being broadcast.
• Check that the Speakers option is set to TV to hear sound from the TV speakers. Possibly sound is being sent to one of the audio outputs for an A/V receiver or headphones.
• If using an A/V receiver, check that the Speakers option is set to AV Receiver to hear sound from the A/V receiver speakers.
Press and hold the POWER button on the control panel for 10 seconds to perform System Reset.
I just bought these LS11. 2 speakers about a week ago. My HDMI output is plugged into my tv and was the source of sound for a while. Now that Im trying to plug these in, I can't get sound to come on for...
I'm confused - 1. I know that a speaker does not need drivers to operate - they just need an amplified audio signal to produce sound. 2. An HDMI output has a digital video and audio signal to transfer from a source like a computer or DVD player to a destination, like a TV set or an AV system. You might have a problem with your sound card in your computer. I think you're missing a AV component system in your set-up - like a physical receiver or AV hardware.
1helpful
Sony bravia kdl- 4052510 picture but no sound from my dvd player
1 Press volume +/- or Mute 2 If it does not work then check if the 'speaker' is set to 'TV speaker' from the "AV set up" menu in "Settings" 3 Press Menu and select Settings. Go up/down and select Set Up icon.Press enter 4 In AV Set up go to speaker and turn on the TV Speaker. This should solve your problem
1helpful
My ps3 has no picture or sound...
if there's absolutely nothing on the TV screen, then most probably the video output is different then the cables you are using (eg: video output HD and you are using AV cables). Are you sure your TV is set correctly? like using HD cable you have to choose HDMI or AV cable choose AV. Anyway, When the PS3 is on, turn it off by pressing and holding the power button on the front (so the light turns red) you will hear beep sound ( I can't remember how many but not once). This should reset the Video output to AV. Swithch to AV cables (if you're using HD). Usually if the system is set to AV output and you switch to HDMI cables, the system recognizes that and swithches to HD output. But if it's set to HD output and you are using AV cables, it doesn't switch back; that is what my system does.
3helpful
Won't play sound out of the AV. 1 and 2
You probably have the av inputs set to digital instead of analog. The easiest way to fix this is to turn the theater system on, turn it to one of the the inputs, then hit menu on the remote. You will cycle through some options with the right arrow until you get to "input", which will offer av 1 and av 2, you can select either one with the ok button. then you will get some more options, analog - optical - coaxial, the first one that shows up is the one you've got currently selected. unless you're using one of the other audio input formats, the system should most likely be set to analog. You will probably need to do this with both inputs.
You have to do this every time the system loses power in my experience.
Just bought SAMSUNG HT X200R HTK home cinema system and I can not get the sound to work through the tv, it does however work through the DVD, can you help?
There are so many things to be consindered 1.does your tv sound comes out from the speaker without connecting the DVD
2.If the speakers from the tv ok,check the av line on the chassis of your tv set/check the av cables
Hitachi snowy screen and noisy
you have broken solder connections inside the tuner, you`ll need a tech as it is soldered in and once removed the board inside will have to be re-soldered. An alternative would be to use the AV outputs of your cable box or vcr to the AV input of your tv, this bypasses the tuner circuit, you will of course have to go into the tv`s menu and switch to AV 1 or AV 2 whichever input you use, good luck& Happy Holidays
Top Nakamichi Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
