Computers & Internet Logo
Posted on Nov 24, 2010
OSD locked. Can't get mouse to work on monitor
Anonymous
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Nov 25, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
13
Questions
0
Helped
4868
Points
31
-Press and hold the MENU button (on the monitor) for several seconds.
-The message "OSD LOCKED" should appear. You can unlock the OSD controls at any time by pushing the MENU button for several seconds. The message "OSD UNLOCKED" should appear
7helpful
"OSD LOCKED" box on my screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
16helpful
2answers
Can not stop monitor from truning on then off. then it says osd locked.
OSD Lock
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for 10 seconds.
plz do rate the solution if helped
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
I have a hp monitor with the number hpf2105 on it
Please see my profile for instruction, or try below, you should also download user manual from HP:
? OSD Lock —The OSD can be enabled or disabled by
“SD Lock”displays for 10 seconds.
?If the OSD is locked, press and hold the Menu button for
?If the OSD is unlocked, press and hold the Menu button
May work the same on other HP model also.
User manual: http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=447388&
If you want to see the inside of your monitor, look here:
http://s807.photobucket.com/home/budm/allalbums
9helpful
Osd locked shows after trying to adjust the volume
To lock or unlock OSD on your Monitor do the following1. Turn off the monitor2. Hold the Menu Button3. Turn on the power by pressing the power button of your monitorNote: make sure you keep the Mouse button pressed while turning on the monitorFor any further assistance please feel free to revert with comments.
Thank you for choosing Fixya
2helpful
The button on the front has functions but when I press either the left hand side or the right hand side it just comes up with a message ''OSD Locked'' What does this mean
OSD Locked means that your On Screen Display is locked. That basically means you can't access/change the menu settings. The way to unlock the OSD varies from manufacturer to manufacturer and even monitor to monitor. Here are a couple different ways to unlock it:
1) The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
OR
2) Go to Menu and select OSD settings and change the setting for the OSD Lock. For example if it is a "+" then make it a "-" or a "On", then make it an "Off", or an "Enable" then make it a "Disable".
If neither of these work, I would contact customer support for your monitor from the manufacturer. They should be able to tell you how to turn off the OSD Lock.
Hope that helps. Good luck!
6helpful
Compaq FP5315 monitor with OSD Lock out
Here is the tip to solve your problem. Hope this might be helpful to you.
OSD Lock—The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message “OSD Lock” displays for five seconds.
❏If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
❏If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
21helpful
5answers
3helpful
4answers
OSD lock out
I HAVE AN OSD LOCKOUT ON MY SCREEN WHICH BRINGS UP THE MAIN MENUE. THE MOUSE DOESNT WORK ON IT TO SWITCH IT OFF!!
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
