How many times red light blinks in tv after you replaced lamp?
Let me know to sort out problem.
Thanks.
Thanks for quick response.
4 times red blinks indicates error with exhaust fans, please check fans are connected and not caught by any thing/ wire etc that can stop any fan.
Let me know your finding to proceed.
Thanks.
Thats great, enjoy good times.
That means exhaust fan is not running on full speed, slow run will also create such problem.
Check fan manually to see is it stuck or moving freely.
Thanks.
6 times blink shows problem with audio chip that is not related with previous problem.
Unplug tv from wall socket for minute to get it reset, replug back in and turn it ON.
Please check tv has enough distance from wall/ shelf for good ventilation as it throws hot air of lamp to maintain internal temp.
Thanks.
hi i hope you can help me out . sony kdf- e55 2000. i replace the bulb but when i try to turn it on 4 green lights blink then turn red lights blink 3 times. can you pls tell me how can i fix this problem.
4 red light blinks
TV working well now....Thanks for your help
After about 5 minutes working it again turned itself off with 4 blinks. I blew out the exhaust fan and again it worked for awhile, but again it turned off. Any suggestions??
I did that and it worked for a couple of hours, now I am getting 6 times red blinks. Any suggestions??
