Question about Franklin Industries Franklin Chef FIM200 Ice Machine
My franklin chef FIM200 is dripping water from the back, right side. The water fill valve was spraying out above the tray, we managed to get that under control, but, water is dripping right behind that valve.
    New Friend:
  • 3 Answers
Try putting a compression coupling in eliminating the valve. Did that on my machine a few months back, have not had any more leaks. Just other issues with thick ice and won't harvest correctly. Any suggestions?
Posted on Feb 01, 2011
6ya staff
SOURCE:
Fim200a does not make the cubes large enough
If you just started having this problem now and it was making the right size ice before then i would first look at cleaning the ice machine including the condenser coil. second thing make sure that the water inlet valve is not seeping water by when it is in freeze mode just a little warmer water will cause it to not make good ice and a longer freeze time. last thing would be to adjust the I.S.Adjust: Ice size adjustment on the control board. Turn screw clockwise, and the size of individual ice cubes will be larger in the next cycle; the cycle time will be longer. Turn the screw counter-clockwise, and the ice will be smaller in the next cycle. only do this if every thing ealse checks out good.
Dec 05, 2013 | Franklin Industries Franklin Chef FIM200...
Machine runs cold water but will not make ice, pump runs and everything else works.
Check the condenser coil to make sure it is cleaned out, also make sure the condenser fan is no dropping out. Next check to make sure the water fill valve is not seeping water past into the sump tray if so than it will not freeze, Water will get cold but not cold enough to freeze check water temp in sump tray with a thermometer to make sure it is getting down to 32 deg.
Oct 01, 2013 | Franklin Industries Franklin Chef FIM200...
Ice maker will make ice but wiil not drop it off into the ben
Hello
you have a sensor plate that is not touching the ice or is not set to the right thickens, that sensor plate should tiger the machine to go in to dump mod.
Thanks
Jul 07, 2011 | Franklin Industries Franklin Chef FIM200...
Were can i buy a water inlet for a franklin ice maker that was brought from HD about 5 years ago.
Gold Star Restaurant Equipment 5 star rating 1 user rating 735 SE Morrison St, Portland, OR 97214 (503) 235-5756 Website. They have everything new and good used, they can get your part. Please let me know how it goes, thanks for using fixya.com. Mike
Jun 06, 2011 | Franklin Industries Franklin Chef 75 lb....
Franklin Industries Franklin Chef FIM200 Ice Machine Logo
195 people viewed this question
Top Franklin Industries Kitchen Appliances - Others Experts
Marvin
Marvin
Irene Tulloch
john h
Are you a Franklin Industries Kitchen Appliances - Other Expert? Answer questions, earn points and help others
