The chattering is exactly what happens when a relay fails. If this is an older model tub, it is likely that you can just replace the ice cube relay. If it is a newer tub, the relay is most likely imprinted into the main cpu board, in which case you have to have somebody put a new relay on the board for you, or replace the control board. If this is an older tub and you need help sourcing parts, you can contact me @
[email protected]
Testimonial: "this solved my problem with the chattering however the heater only heats my spa to 80 degrees do i need a new element or is something else wrong "
