Heating & Cooling Logo
Posted on Nov 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Coleman combustion air switch failed to close
Dann
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 17, 2014
Dann
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
14306
Points
11
Hi, new switch can be found on amazon... here: Amazon com Coleman air switch. I hope this was helpful. Cheers
Anonymous
Level 2:
Scholar:
  • Expert 77 Answers
  • Posted on Nov 24, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
77
Questions
0
Helped
33717
Points
200
If the vacuum switch did not pull in first look to make sure there are no restrictions in the vent pipe if the vent pipe is real long try disconnecting it from the furnace then try to run the furnace again. If that's not it take the rubber hose loose from the combustion blower and **** on it see if the switch itself is bad. If the vent is cleaned out and the vacuum switch sucks in with little effort then your combustion blower in not pulling the proper CFM (cubic feet per minute) and needs to be replaced.
David Spradling
Level 3:
Top Expert:
  • Coleman Master 13,524 Answers
  • Posted on Feb 27, 2022
David Spradling
Coleman Master
Level 3:
Top Expert:
Answers
13524
Questions
0
Helped
929417
Points
28396
Blower motor not running fast enough for safety circuit
DPratt
Level 1:
  • Contributor 2 Answers
  • Posted on Feb 26, 2022
DPratt
Contributor
Level 1:
Answers
Questions
0
Helped
17036
Points
8
Could someone tell me where this switch is located? My furnace comes on when it wants to. If it doesnt this is the same code I get.
5 Related Answers
Anonymous
  • 674 Answers
  • Posted on Sep 16, 2010
SOURCE: the light indicator says that
The combustion air switch is closed by the air pressure from the draft inducer fan. You can check it with a voltmeter. When the heater starts to run check the voltage reading where two wires connect to the switch. It should be 0 vac if the switch is closed. Instead of starting the furnace, you could also remove one end of the rubber hose that goes to it from the draft motor and blow into the hose and see if that closes the switch. It may be just stuck. I almost forgot to mention the most important thing; make sure the draft motor is running. Let me know what you find. The air pressure switch is a safety feature to prevent the furnace from running if there isn't enough air supplied to the burner for proper combustion.
Anonymous
  • Posted on Nov 20, 2011
SOURCE: Evcon, 3 flashes, combustion air switrch failed to
take the switch off and clean it really good and make sure that it turns freely that is how i fixed mine
TheMobilian
Dan Webster
  • 8221 Answers
  • Posted on Nov 02, 2010
SOURCE: combustion air switch failed to
The combustion fan commonly known in the HVAC world as the Draft Inducer has a tube between the fan and the proving switch. The SUCTION from the fan is what causes the switch to trip and verify to the main board the inducer is up and going. Take that rubber hose off and check for obstructions between the two components. This video show basic furnace operation:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Anonymous
  • 415 Answers
  • Posted on Mar 26, 2010
SOURCE: flash code indicates that the combustion air
First, make sure that the draft inducer motor is running. Then check all tubing inside your furnace and ensure there are no kinks, moisture buildup, or cracks.......repair as necessary. Also make sure there are no blockages in your exhaust pipe.
If, after doing these three items, you continue to have a problem, let us know and we'll dig a little deeper. But 99% of the time, your problem is in one of these three areas. :-)
I hope you find this to be very helpful. :-)
Anonymous
SOURCE: turning heater on : combustion air switch failed to close?
i just oiled my switch and made sure that it turned freely and it started working
I have a coleman/evcon model DGAT070bdf I have the thermostat set at 74 but furnace is shutting off at about 64 degrees I did notice that the mother board's green led light is blinking 4 times.
Steady light on - normal operation.
One flash - ignition failure.
Two flashes - combustion air switch stuck closed.
Three flashes - combustion air switch failed to close.
Four flashes - limit switch open.
Five flashes - gas valve energized with no call for heat.
Rapid flashing - reversed polarity.
Note: Color of light is green.
2helpful
Trying to light the coleman furnace and error flashes says "Combustion air switch failed to close. Have turned circut breaker off and tried to start it several times. Cannot even get it to light.
Make sure both the exhaust vent and the air intake vent is clear of any obstruction. If the pipes do not pitch back toward furnace, they may have water in them blocking the flow of air. Also check the condensate drain and pump for blockage.
9helpful
The light indicator says that my combustion air switch failed to close,and i live in a modular home
2answers
Turning heater on : combustion air switch failed to close?
This air switch proves that the inducer motor is running and moving air. If not, check to make sure that the inducer motor starts and that the flue is free of restrictions.....eg. bird nest, ice/snow, or some other critter that found a new home.
1helpful
Heater flashes 3 times says it means combustion switch failed to close
Combustion switch is your vent safety.. Check your vents outside for blockage, sometimes the intake pipe will freeze or frost up not allowing the preassure switch(vent safety)to close. putting furnace into a lock out.. you can reset the furnace by turning the power on and off.. if there is no power switch just remove the bottom door and reinstall...
1helpful
2answers
Furnace shuts off
Defective combustion air switch. The 3 blinks are an error code. You didn't say, but I'm guessing you have a Coleman Evcon. They had alot of defective Combustion air switches. Your specialists were not that.
I have a red t brand furnace. i think it's part of coleman.
could be bad switch but is the vent free and open of all debris or being blocked by anything
Code is flashing on my Coleman Furnace ...Combustion air switch failed to close...we have already replaced the pressure switch ....What else could it be???
safety limit switch,or some people call them a firestat,it has a red reset button in the middle,located in the return with two wires connected to it,detects heat
Top Coleman Heating & Cooling Experts
Paul Carew
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
