SOURCE: GE Nautilus dishwasher wont run
getting ready to try what everyone suggests......wish me luck
SOURCE: My dishwasher keeps beeping at
I tilted mine backwards with it running and beeping and it stopped beeping shortly...It made a mess on the floor of course but I put it down and lights were still flashing but no more beeping. Thought I would try tipping it forward while it was running and the lights went off and the beeping never started again. Its working fine now??
SOURCE: LG Dishwasher Model LDF6810ST Dishwasher won't turn on
your model probably has a coating of a black tar-like substance on the inside of the inner door, which, by design, reduces noise. However, LG failed to notice the corrosive properties of the black tar-like layer. Your wiring harness is probably corroded by the soundproofing, and you will need a new inner door, wiring harness, and circuit board. LG extended my parts warranty because they know it's their fault, Call them at 1-800-243-0000. They will recommend an LG warranty repair certified technician in your area to come out and confirm this. They probably won't extend the warranty until after the tech checks out ur unit. However, labor will be your responsibility.
SOURCE: Baumatic BDW13 14 dishwasher SHowing E3 Fault
I had the same problem and changed the two thermostats on the base and got it working. You can get them from partmasters.co.uk (thermostat protector) cost 17.99. They just screw in and are dead easy to fit
This is a typical GE problem which I have seen many times...When a DW sets for a while not being used...the motor often freezes up....Take the front (lower panel off....find the motor assembly...(with the DW unplugged!!...very important)reach in with you hand or a screw driver...preferably your hand...at the back of the motor...there should be a impeller blade...you should be able to reach in with a finger and pull it down..it may be resistant so find a way to hold it in place as you reach up to the next impller blade and pull down further...finally it will all of a sudden free up....after which you plug it back in and start it up...I am also including a step by step (no drain problem check list as you may run into an issue like this if it has not been operated for a while ....notice article # 5).
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to
see if it is clogged. Unscrew the top cap and see if there is anything
blocking inside. Note: If there is no air gap installed, the dishwasher
might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there
is an air gap installed, it is very common that a hose going from the
air gap into the garbage disposer is clogged. Remove and clean the
hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it
might not be broken, it is recommended that you replace the belt,
because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller,
takes care of the wash cycles, the other, drain impeller, drains the
water out. If the drain impeller is broken (broken blades, shaft), the
dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to
drain water out. Sometimes the solenoid gets stuck, preventing the
water from draining out. Try to free up the solenoid. If unsuccessful,
you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
I hope this helps...it is always useful to include the Model #...more specific instructions can then be provided
Good Luck and good day.....please rate my effort...the Fang
