If first comment doesn't work, than borrow a battery from a known working unit and see if that battery will allow you to make a call. If so, you have a bad batteryIf first comment doesn't work, than borrow a battery from a known working unit and see if that battery will allow you to make a call. If so, you have a bad battery
You can't post conmments that contain an email address.
There must be some internal Hardware problem with pc power convertor(220v to 5v)......
so i suggest u to change the pc power adapter...follow the below link for some of the perfect power adapters
http://www.pcpower.com/products/power_supplies/ultra-quiet/
"be free to ask about further doubts friend....am here to help u based on computers:-)"
hold the power down for 5 secs and it will go itno demo mode and then push the power power agian and it will trun off and thenn push th it one more time and that should work and if that does not work unplug it and leave it unpliged for at least 5 mins and then plug it back in .
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
These symptoms indicates that the belt has gone bad/worn out and belt replacement is recommended repair. Please get back to me with the model# if you have any other questions.
