Technics SH-GE90 Home Equalizer Logo
Posted on Nov 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have technics reciever sa ax 6 (without tape monitor) i have cd player sony xs930 i have cd changer sony 335 i have Technics SH-GE90 Home Equalizer Technics SH-GE70 Equalizer I want to connect all this... Please help me.... Thanks
Anonymous
Level 3:
Guru:
  • Master 2,178 Answers
  • Posted on Nov 23, 2010
Anonymous
Master
Level 3:
Guru:
Answers
2178
Questions
0
Helped
390645
Points
6614
Can I connect an external Technics SH-8036 Stereo Graphic Equalizer to my Technics SA-500 receiver?
You can but you will need to use one of the tape loops to do so. That means you will also have to use the tpae monitor switch of the front panel. Just get 2 sets of interconnects and run one from the tape out to the input of the equalizer and the other from the tape in to the out put of the equalizer.
Hooking up EQ to RECIEVER for a TECHNICS MODEL SH-8017
You'll need 4 connections total. On my integrated amp, I connected the four connections to all Line In and Line Out ports. And the other ends into the tape 2/EXTRA ports respectively.
Technics SH-GE90 DSP gives off high pitch sound, no display in the window,only the red dots down the side and the demo button dose not change demo modes.
Check power supply capacitors.
These are prone to leakage on the SH-GE90 and can cause various
symptoms such as no display or in some cases a flickering display.
The dislay flickers SH GE90.technics .it seems to be a common fault.. can this be fixed
replace the 3 electrolytic capacitors in the power supply section near where the lead from the transformer connects to.
they're sat side by side.
you may notice only 1 might be leaky but replace all 3 for good measure.
i've had quite a few with exactly the same fault and all were cured by replacing the above.
hope this helps?
1helpful
Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
1helpful
3answers
Technics SH -8058
the Technics SH-8058 is a beautiful unit, I got one myself for the past 20 years and never failed y EQuing the sound I want.
I am asuming, you got on your reciever TAPE MONITOR... well, the it is simple,
First, just forget about the TAPE on your Techincs SH 5058
Second, on your Technics LINE OUT, goes on your tape monitor LINE IN
and last; on your LINE IN, goes on your tape monitor REC OUT.
Now, choose you desire componet, and turn on your TAPE MONITOR on your reciever...
enjoy and have fun.
7helpful
USER MANUAL NEEDED
Hi - You can download the manual from the link underlined in blue below:
SH-GE90
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
2answers
Technics su-a808 amp & sh-ge70 graphic equaliser.
connect your media source(dvd-cd player)to equalizer in-connect equalizer out to amplifier line in-or aux in-connect amplifier out to your loudspeaker.
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
