Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
SOURCE: advise use of self clean feature on kenmore self clean oven 30''
If there is an up and down arrow on the control panel, you need to press the clean button first and then choose clean time with the up and down arrow. Be sure to remove the racks, if left in the oven they will be blackened by the extreme heat. Clean them separately with oven cleaner. Place them on newspaper and spray them.
SOURCE: Manual for Self Cleaning 30" oven: Time to self clean
i think you would set it for an hour. because thats what i do on my self cleaning oven. or you could set it as long as you want.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
heatman101
