Either Battery is dead, not charged, or needs to be replaced. Try using another charger overnight and see if takes care of the problem. If not replace the battery. If you have a volt meter you can check the voltage on the battery and on the charger. Expected output voltage is marked on the battery and the charger. You can pick up a cheat volt meter at your local auto parts or hardware store and will help you diagnose your problems.
