LG Shine KE970 Cellular Phone Logo
Posted on Nov 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an lg shine from AT&T and yesterday it would not accept my sim card from AT&T. how do i fix it or is it fixable, i have seen several ppl complain about this very problem my sim card works in my razor but keeps tellin me to insert smartchip if i try to use the shine, can you help.
Anonymous
Level 3:
President:
  • Master 1,010 Answers
  • Posted on Nov 23, 2010
Anonymous
Master
Level 3:
President:
Answers
1010
Questions
0
Helped
266405
Points
3519
If your phone displays the 'Insert correct simcard' then your phone is currently locked to particular network. You need to unlock to use it with other network.
There can be many ways to Unlock your phone. As far as i know unlocking by codes is the simple and safe way. I will suggest the website Unlock-zone.com which is doing good service and they were recommended highly in the cell phone forums.
I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
2answers
Have lg shine need to unlock and dont have at&t anymore what can i do
To get it Unlocked from Network Lock ,get the code from here
Prounlocking.com AND follow the Unlocking instructions below and Unlock it step by step....
Login ' Register ' Currency Pro Unlocking.com Experts in Mobile Phone Unlocking rrmus-8.gif
LG KE970 SHINE lg-ke970.gif Country
Network
LG KE970 SHINE Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your LG KE970 SHINE mobile phones. If you enter over a certain amount of wrong unlock codes on your LG KE970 SHINE mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your LG KE970 SHINE with its ORIGINAL SIM Card.
2 - Then compose : 2945#*9701#.
3 - In the menu that appears go to "Settings".
4 - Then select "Security".
5 - To finish select "SIM Lock" and Enter the Unlock Code.
1helpful
Desbloquear
Currently your LG KE970 Shine Locked to which Country's Network? You need to Unlock it using the Network Unlock code,get the Unlock code from here
Prounlocking and Unlock it...Follow the instructions below and Unlock it step by step...
ORIGINAL: We mean, to use the sim card that was originally given to you by your network/service provider along with the LG KE970 SHINE.
Each LG KE970 SHINE mobile phone has an unique unlock code. You can buy the unique unlock code for your LG KE970 SHINE mobile phone using the form above.
1helpful
2answers
At&t lg prime gs390 free unlock codes
Please see below instructions in details on how to unlock code for LG phones, (i have included various model of LG for you to try)
Here are some unlock codes for AT&T LG phone available, menawhile , including the methods of entering the Unlock Code on your LG phones attached to them. Hope this is useful. AT&T cell phone Questions&Answetrs
Model : AT&T LG VU CU915 & CU920
1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2. Enter *#865625# then the 16 digit unlock code 3. Device should say: Network Lock Deactivated 4. Phone may automatically reboot and is now unlocked !
Model :AT&T LG C2000
Insert non-Cingular SIM card Power on the handset - phone will display "phone restricted" Select "Cancel" - phone will display "phone restriction code" Enter the SIM Unlock code. Select "OK" - the handset is now successfully unlocked
Model : LG TU720 - LG CU720 and all LG Shine SERIES
1) Power ON your phone with an accepted SIM card 2) Type *#865625#UNLOCK CODE 3) Press OK 4) Device is now unlocked
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone; 2) The phone display: Invalid Smart Chip 3) Power on handset 4) Select "Cancel" - phone displays "phone restriction code" 5) Enter the unlock code (8 digit code*) 6) Select "OK'" - the handset is successfully unlocked
Model : LG CU400
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" 3 - Phone will display "Invalid SmartChip" 4 - Enter 159753#*# 5 - Enter the 8 digit SIM Unlock code 6 - Select "OK" 7 - The handset is now successfully unlocked
Model : LG CU500
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN) 3 - In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5 4 - Enter the 8 digit SIM Unlock code 5 - Select "OK" 6 - The handset is now successfully unlocked
How to Unlock LG CU515:
1-Insert non-Cingular SIM card" 2-Power on the handset - Phone will display "Invalid SmartChip". 3-Enter *#865625# then select option 1 and then again select 1 4-Enter the 16 digit SIM Unlock code 5-Device should say: Network Lock Deactivated 6-The handset is unlocked. 7-How to Enter Unlock Codes on CU575 (Trax) How to Enter Unlock Codes on LG F2250:
1-With allowed sim card in the start menu type: 2945#*3311#. 2-Handset shows saved, then return to startup screen 3-Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK' 4-Enter your unlock code and OK. How to Enter Unlock Codes on LG U8110:
1-With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*# 2-Select 'Sim Unlock' menu # 3-Enter NCK code then validate 4-Your phone is now unlocked. How to Enter Unlock Codes on LG U8210:
1-With a not allowed sim card enter Pin code then validate, type: 277634#*# 2-Shows test menu 3-Choose sim test menu and type: 2945#*#, choose Sim Unlock menu 4-Handset shows 'Enter NCK' 5-Enter code, then hit OK. How to Enter Unlock Codes on LG U81xx:
1-To bring up the unlock menu on the phone with a SIM card, type 2945#*88110# 2-Enter the code 3-In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#. If your cell phone is not listed, please follow instructions for LG C2000 above
If If instruction above does not help you i would strogly suggest to contact your Service Provider to provide some alternatives.
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
lg-phones
1helpful
LG shine cu720 how do i save text messages on the sim card
The LG Shine will only save messages to the SIM card after the internal phone memory is full (150 messages). This all happens automatically, and as far as I can tell, there is no way to force the phone to choose. Also, note that the SIM card will only store 30 messages. You can select the options menu
2answers
I turn on my LG Shine cell phone and no matter
Turn off the phone. Take the battery and Sim Card out. Make sure there is no dust or dirt of where the Sim Card goes. Blow air (from your mouth) of where the Sim Card goes. Sometimes rubbing a soft pencil eraser on the Sim Card contact points can help. Then place the Sim Card back in the phone. Make sure it is in the right position; copper contacts facing downward. Put the battery back in your phone. Turn it on, and see if the smartchip rejected goes away.
If not you may need to contact your Phone Provider’s Tech Support to troubleshoot and confirm that you may need a PUK reset code to register or you may need a new Sim Card, as they do fail from time to time.
2answers
Need to Unlock LG SHINE CU720 from ATT
fastunlocking.blogspot.com try this service, very fast and trust.
2helpful
2answers
Lg shine
means sim code has been enetered to many times wrongly, call up the network customer services and they should sort it out :)
LG VU unlock sequence
here's instructions for entering unlock codes for most LG phones: http://www.gsmunlocklabs.com/lg-unlock-code-entry-instructions.php
LG shine CU720
master reset the entire phone
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
