Hi, Switching off the childproof lock 1. Press the ON key. 2. Then immediately press the Plus key of the cooking zone at the left-back and the Minus key of the cooking zone at the right-back simultaneously. 3. Then press the Minus key in order to deactivate the childproof lock. The "L" will go off. If this doesn't work or you have a different model, please post back and I will let you know the correct deactivation method for your model. Hope this helps. Regards, BElectric
You've probably accidentally activated the child-lock "L". It would help to know which model you have as the deactivation method can vary on different models. However, this is the process for activation or deactivation on the EKI-848 which looks like the one in the above picture:
Testimonial: "Thanks for the VERY quick answer! It did help! :)"
