There can be many ways to Unlock your phone. As far as i know unlocking by codes is the simple and safe way. I will suggest the website Unlock-Zone.com which is doing good service and they were recommended highly in the cell phone forums.
I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
Unlocking country code for blackberry 7290
It is very easy to unlock Blackberry cell phone.You can unlock
your Blackberry by follow simple instruction.Contact your carrier
provider for free unlock code.otherwise no one give you free.you
can get MEP code for your Blackberry at cheapest rate by MEP
unlock code provider .after unlocking you will be able to use any
GSM Sim.
Every BlackBerry has "Subsidy code" or "Sim lock code". To remove BlackBerry subsidy code or sim lock a special Blackberry IMEI Unlock Code is needed. By entering Blackberry Unlock Code on your BlackBerry you can use your Blackberry with any GSM and SIM card around the world. Blackberry Unlocking is simplest way to remove any or carrier restrictions from your Blackberry. Remote IMEI unlocking is the safest and fastest way to unlock a cell phone.
Get this Blackberry 7290 Imei Unlock Code .i hope this will help you :)
Good Luck.
Hello, to unlock blackberry 7290 you must know your imei number, mep code and the most important thing a blackberry unlock code. This code will reset your phone network back to factory setting and you can purchase that code at third party sites on internet.
Hi, I am trying to sell my Blackberry, and need to unlock it before I can do so. I purchased an unlock code online, but when I go to OPTIONS>SIM CARD - I get the error message - No Valid Sim Card. Ive tried 2 old sim cards, but so far no luck.
SOURCE: to unlock rim BlackBerry 7290
http://www.unlockitnow.com/Blackberry http://www.unlockanyblackberry.com/
SOURCE: Unlock BlackBerry 7290
Unfortunately, the unlock code for a BB 7290 is unique to each phone. The unlock code is based on the IMEI of your BB. After getting an unlock code then the steps to unlock are:
1. go to options
2 scroll to SIM CARD then press jog dial in once to select it
3. Type MEPD (not case sensitive) ( you will not see text appear on screen while typing )
4. Does it say Network active? if so your phone is locked
5. Press and hold the alt key (half moon looking key on the lower left side)
6. as you are holding the alt key type in MEPE (not case sensitive) ( you will not see text appear on screen while typing )
7. type in the unlock code when prompted
8. After entering the code press the jog dial in
9. Your phone is now unlocked!
SOURCE: blackberry 7290 free unlock codes calculator
Send your Blackberry 7290 to me and I will UNLOCK for $20 and that includes return postage! Email me at "[email protected]" to get the address to send to! I will turn around in 2-3 Business days! Best I can do!
SOURCE: i need an unlock code for my blackberry 7290
i would like to share something with you people which last week i found a company where mobile unlock can be done, so anyboidy need assistance really then, http://www.unlock-zone.com/
There is no such calculator software even somebody have it he will not share it with you. One more thing that you should know, free blackberry 7290 unlock code is not reliable and have higher chance to make your phone hardlocked. So be a wise and try to purchase reliable blackberry unlock code at third party sites rather than screw up your phone.
