Toshiba Satellite L45-S7419 Notebook Logo
Posted on Nov 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What year was this laptop made toshiba satellite pro l450d 12x
Anonymous
Level 3:
Guru:
  • Master 2,178 Answers
  • Posted on Nov 22, 2010
Anonymous
Master
Level 3:
Guru:
Answers
2178
Questions
0
Helped
390284
Points
6614
Since it has a dual core and pre-installed with Vista Home Premium - about five years ago for Toshiba Satellite L45-S7419 15.4-inch Laptop. For the toshiba satellite pro l450d - about a couple years ago.
2 Related Answers
Anonymous
  • 128 Answers
  • Posted on Apr 23, 2010
SOURCE: how do i resore my toshiba satellite pro L450D-12X
Format the drive, then install an operating system such as xp, or windows 7 .... it should install most of the correct drivers. If you have the original disks that came with the computer, use those.You may have to go to the manufactures website to find the exact drivers for the video and sound cards., but that should pretty much return it to factory settings. If you are really picky and have the bucks, you can contact TOSHIBA for the original disks.
PLEASE CLICK ON SOME THUMBS UP FOR THE ADVICE!!!
Anonymous
  • 10 Answers
  • Posted on Mar 14, 2011
SOURCE: How do I enter the
Try this first: Boot the system up and hold down the'Esc' key, then press F1 when you get the check system message. You are then in the BIOS Setup and you can make your changes and save and exit by pressing the 'End' key
If that doesn't work try holding F2 on bootup.
1helpful
Help got a toshiba satellite pro l450d I have no backup disk,fails tests on hard drive disk have attempted fac reset several times with no joy help plz
If the hard drive failed a SMART test then the drive is probably bad and needs to be replaced. Then you will need to contact toshiba to buy a set of recovery dics and reinstall windows from them.
Hi i have a toshiba satellite pro l450d-12x as soon as i start it it goes into a black screen & promps me for a password i have never loaded a password could you please help
This is a security password set in the BIOS. You will need this password to by pass this screen. If you got this pc from someone, you should contact them and request password or do a complete reinstall of the os and loss all data.
Good Luck
C2Solutions
Need a service manual for a Toshiba Pro L450D 12x Laptop
What is your fault as the "Service Manual" contains no schematics just a system flow chart, (which all computer engineers already know) and slightly more information regarding how to drive it and what the acronims means. It doesn't even give part numbers! So I didn't buy it.
Hope I can help.
Where do I find the cmos battery on a satellite pro l450d-12x?
This particular model got it's CMOS (RTC) battery soldered to it's motherboard. You can't just replace it, you should take it to an experienced IT technician, who's good with soldering, in order to de-solder the one that's on board, then solder a new replacement.
Hello I have a toshiba satellite pro L450D-12x while it was shutting down it fell and now when I switch it on i see the toshiba welcome screen and after that it's all black. What can I do to make it...
You may just have knocked the hard drive loose,
Open the hard drive cover remove and refit it. If that does not help, it would be a trip to the repair shop.
You could also refit the memory and cd/dvd drive
2helpful
8helpful
How do i resore my toshiba satellite pro L450D-12X to its factory settings
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
