Question about Philips VOIP8411B/37 IP Phone
Unregistered, registering a new base, faillure....
After used for almost one year, I did something wrong, then always displays " unregistered ", pushing the button of " reg. ", "Registering a new base Please wait ", then " registeration failed " ... no way to do anything... please help me, thanks
  • 2 more comments
  • Zanty Jul 27, 2008
    I have the same problem. I already reset my base unit and my router but I still cannot register.
  • jordaar Dec 29, 2008
    Even I have same problem.... Drop the handset and replaced batteries and now it cannot register to base station... Anyone was able to solve this ?
    Thanks.
    Jor.
  • Anonymous Jan 16, 2009
    Was working fine for over a year. Removed batteries for a couple weeks, after reinstalling batteries, now won't re-register with base.
  • Anonymous May 25, 2009
    Bigbeatpro, thank you so much for you help. I did what you said and my phone works.
IF YOUR HANDSET WAS WORKING AND THEN STOPPED WITH "UNREGISTERED":
If lowercase unregistered is in main display and a reg. appears under the left soft key:
Press the left soft key below REG. and then press and HOLD the button on the top of the base station until the two indicator lights on top of the base station turn off. Wait until handset signals with beeps and registered. You are done
THIS IS FOR FRESH OUT OF THE BOX REGISTRATION OF UNREGISTERED HANDSET
Press REG Register shall be highlighted.
Scroll to Register. Press Select.
Enter the system PIN (Default: 0000). Use
CLEAR to correct typing errors.
Press ENTER to confirm.
• Your handset starts searching for the base.
Press and HOLD the round button on top of the base unit until the two
indications turn off.
• If registration is successful, the signal icon
Posted on Feb 19, 2009
6ya staff
SOURCE:
Deregister cs-6629 handset
If your handset will not deregister, before registering it on a base. Here are the steps;
Menu/Select *7890#
It will display "Test Base" arrow up to "Test Handset"
Press Menu/Select It will display "SW Version"
Arrow up to "next page"
Menu/Select to display "Regstr Clear"
Menu/Select to display "Reg Clear?"
Menu/Select you should hear a beep.
Unplug battery and wait 10 seconds. Lug in battery and place phone in base to register it.
No other handset can be in use when you register new handsets.
Worked great for my 3 handsets that were registered to a base that went bad.
Nov 26, 2012 | Vtech DS6151 Cordless Phone
The handsets are displaying 'UNREGISTERED' and not working!
UNREGISTERED means the phone has not yet been set up to work with any particular base. I don't have any Phillips phones, so I can't tell you the procedure, but it should be outlined in the owners manual. Look for registering your handsets.
Jul 31, 2009 | Philips Lands Phones
Registering a new phone
how do i register my new samsung rant phone ?
Oct 04, 2008 | Uniden DCT648-3 Cordless Phone
Tesco arc200
I solved it out u must pres de paging button on the base while registering the phone to base keep the paging button pressed until starts to beep like 5-10 sec. Good Luck
May 16, 2008 | Uniden Cordless Phone
Dect 1221
On you base between Clear and intercon push middle button, with erow push display base -ID
Apr 07, 2008 | AT&T E5965C Cordless Phone
Phillips dect2152
If you bought the base and handset together they should already be registered. If not then the instruction manual is downloadable here: MANUAL
The relevant section is on page 16 - here is a copy:
4 handsets can be registered to the base station. A handset
can only be associated with 1 base station.
�� To register another handset
First enter registration mode by unplugging and
plugging back in the power adapter to the
electricity supply.
Handsets registering / unregistering ( )
�� To unregister the handset you use
enter the RC code*
�� To unregister all the handsets (except the handset you are using)
enter the RC code*
Once the menu is selected, enter the RC* code written under the base and press
to confirm.
Warning : If you wish to associate a non-Philips handset to the DECT 211 or DECT 215 base
stations, make sure that these handsets are GAP compliant otherwise they will not operate properly.
*RC code
(Registration
Code) is
written under
the base.
Warning : Once unregistered, the handset is no longer operational.
Please rate my assistance this should be a fixya!
Mar 29, 2008 | Philips DECT 2151 Cordless Phone
Got instruction to unregister KX-TG6074B
If this error message displays on your handset, please follow the instructions below to deregister your old handset before registering a new handset.
1) On the base unit:
Press: FUNCTION or PROGRAM
Button name varies by phone model.
2) Press: MUTE
3) Enter the numbers 3, 3, 5, #
4) Enter the handset number (1 to 8)
Mar 14, 2008 | Panasonic KX-TG2740 Cordless Phone
Tru9466 base and tru9465-2 handset
Same manual as lethean provided on a similar post but Page 24 if the previously used Base is Unavailable and your phone shows "Deregistration" in the Menu.
Base Unavailable (Handset Only)
To clear the base registration data in the handset, please follow these steps:
Press and hold [] and [#] for more than 5 seconds. Select the BASE UNAVAILABLE submenu.
BASE UNAVAILABLE appears. Move the cursor to select YES, and then press the OK soft key.
ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
Mar 10, 2008 | Uniden TCX905 Cordless Accessory Handset...
Getting a new mobile in the registration mode with my Gigaset 8825 base station.
You need to register the handset to your base. Its easy, but first you need to clear the setting on the handset. Do this by pushing Menu, scroll to base system settings, push OK, then scroll to Base station 1, push OK, then scroll down to deregister, push OK twice, then press End. The handset should now say "please register", of which you can press OK, enter your pin or 0000 and the display should be flashing "registering base station 1". Now quickly, at your base push Menu, scroll forward to system settings, push select, enter your pin or 0000, then select. Push select again and the display should say "registering HS". Now, both displays (base and handset should say registering), keep your eyes on your handset display, once it "shakes hands" with the base it will prompt you to select an intercom number, you can just push OK. If you have problems, repeat the steps or you can download a manual for free at www.cordlessrepair.com
Oct 18, 2007 | Siemens Gigaset 8825 Cordless Phone
Philips VOIP8411B/37 IP Phone Logo
1,296 people viewed this question
Top Philips Computers & Internet Experts
Ekse
Herb Box
Herb Box
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
