Doro DECT 850 Cordless Phone Logo
Posted on Jun 22, 2008
Doro 5065 - changing outgoing message
I have lost the instructions for my Doro 5065 phone and i want to change the answering machine message and increase the amount of rings before the answering machine cuts in - can anyone help, please?
Anonymous
Level 1:
Problem Solver:
  • Contributor 3 Answers
  • Posted on Nov 04, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
1654
Points
5
Go to:
http://www.doro.com/global/businessunit/dorocare/support/imagesdownloads
Type in your phone model number. Scroll down to PDF and download in your language.
How do I change my outgoing message
I need the phone Model # ? You can go online and google the phone and how to get through the menu options.
Resetting answering machine message, lost instruction manual
goto this wepage put in your model number and you can download your replacement manual.
http://www.doro.com/global/businessunit/dorohome/support/manuals
Reset base unit defaults
Resetting will return most functions to the original factory default setting.
Registrations are not affected by resetting.
1. Press Menu.
2. Scroll using v/V to Base Set. Press OK.
3. Scroll using v/V to Default Set. Press OK.
4. Enter your current base unit PIN code (0000 at default).
5. Press OK to confirm.
Bought second hand i how do I change the answer phone message to mine?
Hello. I have located the owner manual for your phone and I will provide the link at the end of this response. If all you wish to do is change the outgoing message to your own, do the following:
The OGM is your announcement to the caller and may be up to 2 minute in length. If
you choose not to record your own OGM, the caller will hear a prerecorded OGM. Use
your OGM to advise the caller to begin talking after a beep is heard. For example:
“Hello, we are unable to take your call right now, please leave a message after the beep,
and we’ll return your call as soon as possible. Thank you for calling.”
Recording your OGM
1. Press .
2. The total number of (new) recorded ICM’s will now be announced.
3. Press 8 to stop playback.
4. Press 4 5.
5. Record your OGM.
6. Press 8 to stop recording.
7. Your OGM will be repeated after a few seconds. Repeat the same procedure if
you wish to change the OGM. Any old OGM will automatically be erased when
a new one is recorded.
Here is the link I promised: http://www.doro.com/global/businessunit/dorocare/support/imagesdownloads
please rate my answer. thanks. Regards, Joe
Lost manual, need to change my outgoing msg on aswering machine..
You can download a copy of the manual from the manufacturer's web site at http://uniden.com/index/manuals_results.cfm?cat=59
How to reprogram the outgoing message on an answering machine
I have an answermate 62255 but mine is labeled Bell. Open
the casette compartment. There is a button labeled ogm. Hold
down until the unit beeps. Record your message and press stop
when finished. It will play your message back. Repeat until you
are satisfied
Lost the manual. how do i change the outgoing
You can download the manual at http://uniden.com/pdf/DCT5280om.pdf
3helpful
3answers
How to re-record our anwering machine message Doro 615R+2
Push the top left button (looks like an audio tape).
Then push 9
It will display a 180second count down in which to record your voice message.
When finished, push the top right button (looks like and arrow into a diamond).
To turn off/on the answering machine:
I lost my user manual for my Doro 615R+1 home phone, so after much deliberation and playing with many buttom combinations, worked out how to turn off the answering machine.
- Open the answering machine function by pushing the top left button (looks like an audio tape).
- Push '0' and then use the up and down arrows to select On or Off.
- To enter your selection push the top right button (looks like and arrow into a diamond).
Done :-)
15helpful
3answers
How to get the messages of doro 615R+2 digital phone
Then push 5 (has a play symbol on it)
You can use 4 and 6 to navigate saved messages or use # (has a 'X' on it too, to delete messages).
- To enter your selection puch the top right button (looks like and arrow into a diamond).
Done :-)
1helpful
4answers
Doro 133R phone - answering machine not working
a bit late for this persons problem, but if anyone needs a manual here's the doro site - just type in the model number and you will be able to download the pdf.... http://www.doro.com/global/businessunit/dorocare/support/imagesdownloads
Top Doro Lands Phones Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Doro Lands Phone Expert? Answer questions, earn points and help others
