the error P 0 8 means that the ink level in the cartridges is not recognized.
On
the printers control board you have a buton that is called
Resume/Cancel, it is the buton near the copy black and copy color
butons. You can recognize it by the red triangle in a red circle.
Press
this buton for at least 10 seconds, if the error is not gone from the
first time press and hold the buton for at least 10 seconds for the
second time.
Now the printer will have the ink level counter disabled but do not worrie it will worj just as well.
1. Turn Off
printer, cable power still plug in.
2. Press
Stop/Reset button, don't release the button.
3. Press Power
button by holding without release and than release Stop/Reset Button.
4. Press
Stop/Reset button two times (2x) now release the Power Button.
5. Wait until
service mode to zero (0).
6. Turn off
the Printer, cable power still plug in.
7. Press
Stop/Reset button, don't release it.
8. Press Power
button don't release & than release Stop/Release button.
9. Press
Stop/Reset button four times (4x), wait until service mode to "1"
10. Turn off
printer, and loose cable power, wait for one (1) minute.
Connect
cable power, turn on printer again, now this printer ready to use
Indicator appears blinking lights on the printer " P,O, 8′. That Mean The print head temperature above the specified value. You can replace the ink cartridge or refill the cartridge.
Step to resolv this error
Step 1 : Turn Off Printer
Step 2 : Remove Cartridge
Step 3 : Refilling the cartridge
Step 4 : Reinstall the cartridge
Step 5 : Turn The printer ON
If it still does not work you can use the following methods
How To Reset MP 258 error 5200
Step 1 : The printer is off and plug the power cord.
Step 2 : Press the button STOP / RESET and hold, then press and hold the POWER button
Step 3 : POWER button still press, release the STOP / RESET, then press the STOP / RESET 2 times in a state of the power button is pressed.
Step 4 : Release both buttons simultaneously
Step 5 : The printer will proceed in a while (a while), then the LCD panel will show the number zero (0)
Step 6 : Computer will detect NEW DEVICE, Ignore it...
Step 7 : Press the power button, then the printer will turn off
Step 8 : Press the power button again, then the printer will be ready to use
