You can adopt following tips before dying your hair:
1. Follow the directions in the package. Pay attention to all Caution and Warning statements.
2. Use less toxic dyes.
3. Never dye your eyebrows or eyelashes. This can hurt your eyes.
4. Keep hair dyes out of the reach of children.
5. Wear gloves when you apply the hair dye.
6. Don't leave the dye on longer than the directions say you should.
http://www.procuffs.com/Gunmetal-USB-8Gb-Cufflinks-p/pc91.htm
You should follow these safety tips when dying your hair:
•Don't leave the dye on your head any longer than needed.
•Rinse your scalp thoroughly with water after use.
•Wear gloves when applying hair dye.
•Carefully follow the directions in the hair dye package.
•Never mix different hair dye products.
•Be sure to do a patch test for allergic reactions before applying the dye to your hair. Almost all hair dye products include instructions for doing a patch test. It's important to do this each time you dye your hair. Your hairdresser should also do the patch test before dyeing your hair. To test, put a dab of hair dye behind your ear, and don't wash it off for two days. If you don't have any signs of allergic reaction, such as itching, burning, or redness at the test spot, you can be somewhat sure that you won't have a reaction to the dye applied to your hair. If you do react to the patch test, do the same test with different brands or colors until you find one to which you're not allergic.
•Never dye your eyebrows or eyelashes. An allergic reaction to dye could cause swelling or increase risk of infection in the eye area. This can harm the eye and even cause blindness. Spilling dye into the eye by accident could also cause permanent damage. FDA bans the use of hair dyes for eyelash and eyebrow tinting or dyeing even in beauty salons.
