Televison & Video Logo
Posted on Nov 22, 2010
I have a Samsung HD TV and it's been working well for about 3 years and now all of a sudden the tv screen won't work. Well i mean it works but all I can see is a black screen with some broken blue lines. At first i thought it was my cable that was the problem but when I tried to play my DVD, the screen was still blank with broken lines running across.
Anonymous
Level 1:
New Friend:
  • Contributor 29 Answers
  • Posted on Nov 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
29
Questions
0
Helped
2873
Points
87
Try making sure the video cables are properly attached
2answers
HDMI quit working with store bought DVDs
so you have to update a new firmware and then it will be ok
How to repair my Samsung TV? When the TV is turned on it powers on and off non stop until unplugged.
Hi, the motherboard could have been affected. Since you have ever replaced the power supply, its better you get a new motherboard.
No HD pic on Samsung HP-R5250
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
My UN60D6500 won't go into full screen or fit screen all of the sudden
Sounds like a decoder issue, or the signal that is being transmitted to the TV is not HD
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Smashed glass screeen on samsung 50 inch plasma tv how much to fix is it worth it
Most of the times smashed screen means the end of plasma tv. Although if your tv model is older than 3 years, you could search for same model broken tv's with working screens since power supplies usually last for a few years in modern flat panels. Though you will need a qualified serviceman to do the assembly from two faulty units into a working one.
15helpful
Samsung LE26R73BDX 26INCH - LOSS OF DIGITAL SERVICE
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
