Tip & How-To about Computers & Internet
Question: How do I bypass a Windows 7 account password if the only account I can access is guest? Can I bypass Windows 7 password
with the guest account? I forgot my Windows 7 administrator password,
how can I regain access to my computer without the password? I have no
Windows password reset disk.
Recently I met many similar questions. Are you troubled with the same
problem, also forgot Windows 7 password? Well, before answering the
question, you should understand what a guest account is?
What is a guest account in your Windows 7?
The guest account in your Windows 7 only allows people to use your
computer without having access to your personal files. With the guest
account, you can't install any software or hardware, change settings, or
create a password. Because the guest account allows a user to log on to
a network, browse the Internet, and shut down the computer, you should
disable the guest account when it isn't being used.
Solution: After learning the definition of a guest account, you can understand it is not possible for you to bypass Windows 7 user password through
the guest account. But you can bypass your Windows 7 password, with
Windows Password Recovery Tool 3.0, a safe and efficient tool for you to
bypass Windows 7 password. It allows you to bypass your lost Windows 7
password in less than 5 minutes.
What is Windows Password Recovery Tool 3.0?
Windows Password Recovery Tool 3.0 is professional Windows password
reset software with 3 editions: Windows Password Recovery Tool 3.0
Standard, Windows Password Recovery Tool 3.0 Professional and Windows
Password Recovery Tool 3.0 Enterprise.
It is designed to bypass Windows domain password, Windows administrator
password and user password. With this Windows password recovery tool,
you can instantly regain access to your locked computer by burning a
bootable CD/DVD or USB flash drive on your own. No need to reinstall
computer or pay to PC experts when you forgot administrator password or
domain password on Windows 7/Vista/XP/NT and Windows Server
2008(R2)/2003(R2)/2000.
How to bypass Windows 7 password easily?
Step 1: Download and install Windows Password Recovery Tool 3.0 Professional.
Step 2: Burn bootable CD/DVD or USB flash drive.
Step 3: Set your locked computer to boot from CD ROM or USB.
Step 4: Choose the installation path of Windows, and enter the ID of the path.
Step 5: All Windows account user names will be displayed for you. Enter
the ID of a specified User Name to remove its account password.
Step 6: Enter y to confirm and continue your operation.
Step 7: Enter y to remove another Windows account password or enter n to
finish your operation when the selected windows account password is
removed.
Step 8: Take the burned USB flash drive out of computer and press any
key to restart your computer when you enter n to finish your operation.
The Windows 7 administrator password has been successfully reset and now
you can access your computer without password. Please note this method
to bypass Windows 7 password takes effect only when you log on computer
after Windows 7 password reset.
