SOURCE: Bose surround sound system cuts off
Hi when you turn on check all your speakers work check connections make sure the wire has no stray strands touching the fault could be in the sub unit this is possible / or your speakers one or more could have gone short circuit due to exessive volume thats if you play loud. Had a party lately .Just joking .Regards kirk
SOURCE: No surround sound
It sounds like the speaker wires are mixed up or maybe a setting on the reciever is wrong. Verify your speakers are properly connected. you test speakers using a 9 volt battery or smaller.
SOURCE: hooking up a Bose Lifestyle 30 II to an optical audio output
Actually, you can do this. Just get an optical to RCA converter.
This looks like a good one:
http://www.amazon.com/Cables-Go-40019-Optical-Converter/dp/B0002GV876/ref=pd_cp_e_2
SOURCE: I have the speakers and
When they don't publish trhe specs such as power output or speaker impedance and power-handling capacity that means it's a SYSTEM.
Proprietary cabling is a huge clue that these speakers are not necessarily electrically compatible with any other electronics.
