Panasonic Viera TH-42PX80U Plasma TV Logo
Posted on Nov 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Any tips on repairing plasma screens when the have been scratched please.
Anonymous
Level 2:
Novelist:
  • Expert 131 Answers
  • Posted on Nov 21, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
131
Questions
0
Helped
41178
Points
422
Hello; First you need to know if the scratched part is plastic or glass. I believe my Panasonic Viera plasma has a glass outer screen. I would start looking at kits to repair scratched eyeglasses or car windsheilds. There are also kits for plastics for either of these. Check with auto parts stores or EBAY Good luck! John
3 Related Answers
Anonymous
  • 265 Answers
  • Posted on Aug 11, 2009
SOURCE: plasma tv scratch
Things You’ll Need:
* Television screen cleaning products
* Cleaning schedule
* Microfiber cleaning cloth
Clean Your HDTV Screen Properly
Step1
Read the warning labels on all your household cleaning products. Even glass cleaners might not be suitable for use on an HDTV screen, so check the manufacturer's warnings before you apply anything to the screen.
Step2
Keep chemical cleaners away from your HDTV on cleaning day. The harsh chemicals found in most common cleaning products will actually cause more harm than good.
Step3
Leave liquid cleaners under your sink when cleaning your HDTV screen. A liquid cleaner, whether it be water or a chemical cleaner, will drip down the screen and work its way into the interior of the TV, causing damage to your HDTV. You will be able to easily recognize when this happens, because your screen will develop smudges.
Step4
Use a cloth to clean the HDTV screen. Ideally, you should use a cloth that is recommended for HDTV screens, computer screens and other electronics. The word "microfiber" may be imprinted on the packaging.
Step5
Wet the microfiber cloth slightly. Just a hint of dampness is all you need. If water runs out of the cloth, then it's too wet and will cause smudges.
Step6
Develop a regular cleaning schedule for your HDTV screen. If you dust the screen daily, or at least several times a week, with your microfiber cloth, no other maintenance should be necessary. Not only will frequent cleanings make caring for your HDTV easier, but they will also enhance your viewing experience.
Step7
Prevent messes by asking family members and guests not to touch the television screen. You should also try to make sure children with sticky fingers do not come in contact with the screen.
Step8
Use a high-end cleaning product if you feel that regular dusting is not sufficient. Top-of-the-line television cleaning products are ideal for use on all HDTV screens, plasma screens, projectors and are safe to use around children and animals.
dave1645
Dave Naylor
  • 834 Answers
  • Posted on Dec 15, 2009
SOURCE: removing scratches on plasma screen
try calling a glass store and i believe they do have a polish that will take them out but be very careful that glass will break
VERY easy
Anonymous
  • 382 Answers
  • Posted on Jan 01, 2010
SOURCE: I need to repair a scratch on my panasonic 42
It is glass but it may have a treatment on the surface, typically cleaning it will help. Buff with a microfiber cloth.
1helpful
How to repair a scratched plasma tv screen?
Since the screen is very thin, it is very difficult to do even buffing. Contact the service providers for any solution. My guess is you may have to replace the display. In that case, it is better to wait for a major defect in the TV.
3helpful
Removing scratches on plasma screen
VERY easy
2answers
I have a 4inch scratch on my 42inch samsung plasma screen how can i repair it.
The only thing you try to do is polish it out (dependent on the severity)
1helpful
Scratch on plasma screen
You should be able to make the scratch become invisible using a white eraser. A pink one will work, but the white one works better. Just simply erase the scratch, it may take awhile, but your basically buffing the surface down even again making the scratch un-noticeable.
Scratched plasma tv screen
If the installer scratched it, then surely he is liable (under his insurance) to replace it, or get it repaired.
Don't waste your time with attempting to get rid of the scratch.
INSTALLER IS AT FAULT - ROOT CAUSE ESTABLISHED
INSTALLER CONDUCT CORRECTIVE ACTION - REPLACE...
My plasma tv has several really deep scratches on the screen, how can i go about repairing this?
There are liquid solutions for filling LCD scratches
it's basically a plastic material that fills the scratch.
Big scratches are more of a problem. I am assuming that your
Plasma screen has a glass surface and that it's only scratched,
not physically broken. You may also try glass polishing compounds
for filling and polishing chipped windshields. Be careful, try it on a small spot first to make sure that you don't dissolve any plastic anti-reflection coatings etc.
Good luck
2answers
Broken plasma screen
dont bother m8 they cost the earth .at leat £2500
Nec plasmasync 4200w 3 vertical lines one yellow two purple
Sorry to tell you, it is not a scratch, but a bad cable connection from the driver IC's, connecting up the plasma screen to the drive board, or the drive IC for that section of the screen is defective. It is not a repair a user can do as there are no user replaceable parts inside this set. Your going to have to call NEC or an experienced Plasma repair shop.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
