Hi, if you still seeking a practical solution to download songs from PC to iPhone, then you may have a look at this one: https://bit.ly/2V7t2BE
Step 1. Connect your iPhone to PC via matched USB cable.
Step 2. Click the phone icon on the left corner of the interface. To manage your media files manually, you'd better go to "Options" under "Summary" tab, cancel "Automatically sync when this iPhone is connected" and check "Manually manage music and videos". Don't forget to click "Apply" when it's done.
Step 3. Import music into iTunes library from computer by clicking "File" and then "Add File to Library". Once transferred successfully, you can select the music icon on top to see all the songs.
Step 4. Click "Music" under "Settings" tab. Choose "Sync Music". You can either sync entire music library or selected playlists as you like. Then click "Sync" button at the bottom.
How to Transfer Music from Computer to iPhone 5s
As I know, Apple Remove Free Music Download Apps. So, if you want to download songs from pc itunes to iphone, you may need an iTunes Alternative that transfer free downloads to iPhone. You may read this article related and it provides solution: Why Free Music Download Apps Removed from Apple Store
Hey,
Well, since you're using an Apple iPhone, you will also need to use Apple iTunes to hold your music. To import your iTunes library to your iPhone, you must:
1) Connect your iPhone to your PC.
2) Wait for iTunes to recognize your iPhone.
3) Press Sync to transfer data, including music, from your computer to your phone.
4) After the sync is done, you should open your iPod app on your iPhone to listen to the transferred music.
*Note: You might also want to make sure that you're actually syncing your music by clicking on the "Music" tab after you click your iPhone on the left panel, and then checking the boxes next to the options for the music you want to sync; whether your entire library or just specific playlists.
Glad to help.
-virjog
There are 2 ways,
1) sync music to your iphone through itunes by selecting the music tab on itunes and select the song you want to sync
2) sync by manually dragging your music to the iphone icon in itunes. you will need to click off the box "manually sync files to iphone" at the bottom of itunes
SOURCE: cannot sync iphone to itunes
format the i phone after backup,use the new version of itunes
you not mentioned your i phone model
SOURCE: cant syn music form itunes
you have to use itunes import your music in there and make a playlist first and make sure you have enough room when you attach your iphone select it and choose the playlist you like to import music.
SOURCE: apple iphone A1203
Hi eveyrone I 've got an old version of Iphone A 1203, accidentially I upgraded it to 3.2.1, now it does not support my simcard. Its original software is 1.1.4 how i can downgrade it to 1.1.4 or is there any ther solution do solve this problem please help me it's urgent
