When I turn my camera on, I can view pics in camera but when turned to take new pic mode the screen is black.
Was this your problem and did you get an answer?
Thanks,
LK
One configuration option for the F700 is to turn off the LCD when taking pictures and use the view finder-- this saves battery power. If you press the DISP button to the right of the LCD should turn on.
To turn the LCD back on-- Press MENU/OK (you should see the SELF TIMER screen). Press RIGHT ARROW to select the SET option. Press UP ARROW to select the SETUP option. Press MENU/OK. You should see the SET-UP screen. Use the UP/DOWN Arrows to navigate the options; use the LEFT/RIGHT Arrows to cycle through the options. The IMAGE DISP and the LCD options control when the LCD is powered on.
I own 2 fuji finepix f700 digital cameras, bought them at the same time. One camera has black screen on pic taking mode and shows up only black when viewing the pic, everything else works fine.
The second camera, everything works well but screen shows all black and sometimes blurred lines of colors, this same shows up when viewing pic.
I have cleaned battery terminals and memory cards contacts. Neither camera falls under the serial #'s on the list of defaulted cameras.
