I need the fuel hose diagram for Husqvarna leaf blower blower
Try these sites, first, the exploded view part diagram for ordering parts http://weborder.husqvarna.com/order_static/doc/HIUS/HIUS2008/HIUS2008_545103429.pdf
second, (if this is not the right manual) then try this to find it, http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=&types=O,I
good luck!!
well, thanks anyway. I went to zama and will try in the am. None of what I could find helped, so went to the carb maker
#1) Run one line through rubber stopper in top of tank. Attach fuel filter to end that goes in tank (leave enough line so filter will lay in bottom of tank.) Attach other end of same fuel line to bottom tube coming off of bottom of carburetor (make sure it does not kink). #2) Run 2nd fuel line from bottom tube on primer bulb (or tube that expels air when bulb is pressed) run other end into rubber stopper just through the top (this end stops flush with under side of rubber stopper). #3) Take a 3rd fuel line and run from top tube on carburetor to top tube of primer bulb (tube that draws air when bulb is pressed). Stopper can be pulled out to achieve this and put in last.
Take 1 fuel line with filter attached to one end. This line needs to be fed through the rubber stopper (with 2 holes that goes in top of tank) and continue to bottom tube coming from carburetor. Take a 2nd fuel line from primer bulbs bottom tube and feed into 2nd hole in rubber stopper. This fuel line stops just after it goes through stopper and does not go down in tank. Take a 3rd fuel line from top tube coming from carb and connect to second tube coming from primer bulb.
