Sounds like the blower motor is not working, if the furnace is actually lighting up and the burns are ignited. You should set your thermostat to auto, as if it is on fan then the fan runs all the time until you take it off of fan. I am a little confused and since I am not there I will give you a website that will walk you through the ignition process, this way we can eliminate flame sensor,ignitor, pressure switch,roll out switch, board,etc. I really hope this helps as I know what it is like to be in a cold house. Good Luck Tim
Probably your ignitor is bad...
Here
is a tip that will help you try to figure out why your furnace is not
working.
Basic
Furnace or Heating System Troubleshooting
heatman101
