SOURCE: cpu
are u using amd turion ... in the case of laptops the temeprature of near 65 can be said as normal antivirus and hidden virus activities can also increse cpu usage and cause over heating . i am using amd turion i usally get temperture upto 65 dg . note at which processes the cpu temperture increases
SOURCE: Acer Aspire 3680-2022
i formated my aspire 3680-2022 for winXP now my sound and wireless network doesn't work anymore
SOURCE: my acer aspire 5515 laptop runs real slow its only 1mo. old
Yes, you can safely uninstall the acer game zone.
You should defragment the hard drive with Defraggler (http://www.filehippo.com/download_defraggler/)
and clean temporary files with CCleaner (http://www.filehippo.com/download_ccleaner/) and eventually scan for spyware with Ad-Aware or Spybot, oh, and also a full system virus scan wouldn't hurt either.
You could also disable some programs which load at startup via Start -> Run -> type "msconfig" (without the quotes) -> Startup and disable not needed items.
SOURCE: Acer Aspire 3003LCI Laptop Fan starts but stops after 5 seconds
remove the memory then make a clean or replace a new memory
SOURCE: i have an acer aspire 5735z laptop webcam
Dear Sir,
Acer Aspire Model generally comes with a bison web cam driver.
To use the web cam search for an application that installed in program files.In windows Xp web cam can be used by double clicking camera icon present in my computer. If you are using windows vista or other operating system you need an camera application software,to use it. Without application software you can use your web camera only in messengers,for example yahoo messenger. If u had an yahoo messenger login and click on view my web cam,now you can see your face in your laptop.So first thing is search for an application software installed on your laptop.
good luck
