If the photo shoot out show white , the obscure (quality variation), and even horizontal line ( white lines), and so on over-exposure cases, even if the use of anti-tremor, set to default values are invalid, because the camera shutter fault.
This is a common problem. The metering and light balance are the reasons that you are having problems achieving good results with your photos.
All cameras on the auto cycle are calibrated for 18% gray. Another words a photo of all white results in 18% gray. A photo of black results in 18% gray. The camera adjusts the shutter speed and aperture to achieve an average light level of 18%. That is why photos of snow always appear gray. To compensate for this characteristic of the cameras an 18 % gray panel is held in front of the camera and than the settings are set.manually. The metering in the camera is now locked and using the same light levels objects will be in their natural level.
A second problem is the white balance. Using flash avoids some of these problems. Adjusting the camera for source lighting type will help the most. The light balance is the cause of discoloration of the objects in the photo. Usually the camera white balance can be set for auto, incandescent, fluorescent, outdoor or flash,
Use a manual setting if it is available on you camera, You need to adjust the settings until you get acceptable results. If the photo is dark add light by reducing the aperture number to a lower number allowing more light. After the aperture is open wide(lowest number) increase the exposure to longer time. With very low light levels a tripod may be necessary.. After doing this once record the numbers for next time.
Once you've taken the picture, the date stamp is just more pixels, exactly as if you've taken a picture of a sign with the date on it. Just as a sign hides what's behind it, the date stamp covers whatever was there.
You can use a photo editing program to remove it the same way as removing any unwanted object in the picture. You can crop the picture, or use a cloning tool to try to extend the background to cover the date.
Unless you want to colorize them by hand, there's no way to add color to black and white photos. Given a black and white photo showing a person in a gray dress, how do you know whether the dress was blue or red or some other color?
Not really a solution yet but we really don't know if the problem is with your camera or your printer. If you can, remove your memory card and take it to your nearest photo retailer (I like WalMart). Ask the technician there to help you make a photo of the offending image. If the background is gray on the new photo, the problem is with your camera. If not, it is likely your printer.
Your camera may have settings that can be adjusted as well.
Also, if you're using standard copy paper instead of photo paper to print your picture, there may be color issues as well.
Hope this helps.
I think your camera chip is dying soon. Try taking a photo on a blank sheet of paper, black and white, see if there are lines. If there is, it shows that the camera chip is defective...
Can't repair by yourself. It's need repair camera machine shutter.
i just got a new camera the dimagne x50 and i brang it out today and it was working fine it didnt drop or anything i took a picture then turned it off then i turned it on agian and when it was on the camera format the light kept on blinking yellow for the longest time and wouldnt let me take a picture so i tried the video format and it worked so im just wondering why the video format is working and not the camera ? has this happened to you? is there any way of fixing it?
I also have the same problem! I absolutely love this camera but suddenly out of the blue I have stripy lines on the screen that look like you are looking through a venetian blind. I have contacted Fuji but they say it will cost £99 to repair or have offered £50 discount on any other camera. I just want my F460 working ok. Please, please can anyone help us?
same problem on mine...
for what I read a lot more complains about it...
i believe it's a factory mistake (??)
