What are the tv remote codes for Prima tvs when using universal remote controls like those owned by Dish Network?
We'rehappy to help you with programming your DISH Network remote to your Prima TV.Start by pressing and holding the TV button located on the top of your remoteuntil all mode button back lights come on, and then release. Use the numberbuttons to enter the codes for your Prima TV; here are some of the codes wecurrently have for it: 674, 653, 673, 912, and 842. Press the pound (#) button.To check that the code works try several different functions on the remote tomake sure it will properly operate the TV. Remember that some codes may not becompatible with your TV. If this is the case, try the other codes listed foryour Prima TV until you find one that is compatible with it.
Ifnone of the above codes worked we recommend performing a power scan:
Power scan instructions:
Step 1:
Press and hold the TV mode button until all mode button back lights illuminate,then release.
Step 2:
Press and release the Power button.
Step 3:
Press the Up button once a second while pointing the remote at the desiredequipment. If the code for the equipment comes up, the equipment will poweroff.
Step 4:
Press the pound (#) button. If the code entered is valid for the remote, themode light flashes three times.
After doing the power scan please remember to put the remote back into SATmode. We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
