> Settings > Application Settings > Call > All Calls > Auto Reject. You can then set the activation to off or delete a number from the auto reject list.
wow superb , was breaking ma head to remove a number, by mistook added a no in reject when that person calls i was unable pick up his call,he was annoyed... thanks you.....riaz
very helpful indeed. ihad to remove both my sims insert another two sims thn remove thm and add my sims so in ths way i wud remove a number. but ths was very helpful, thanks alot
thank you very much you really helped me
SOURCE: removing a number from reject list in my Samsung GT-S5233A.
Hi ,
just go into menu , settings , application settings(5), call (1), all calls( 1) , auto Reject (2), scroll down to reject list and you will find all numbers added to it, simply delete them and they will be back as normal in your phonebook,
hope that'll help you
SOURCE: accidently add number in reject
Go to settings = application settings = call = all calls = auto reject = reject list
SOURCE: Removing Numbers from Reject list Samsung u900
Main Menu> Settings> Call Settings> All Calls> Auto Reject> Reject List> Delete the number out of the list.
Adam
SOURCE: removing numbers from reject list in samsung f480
Goto
Settings-->Call settings-->All calls-->Auto reject
Click on 'Reject list'
Here just for making them to be receivable calls, uncheck them
If you want to completely remove, you need to click on each entry and then press Options-->Delete. But the problem with deletion is you need to do that for each entry separately.
SOURCE: how to remove the number
how to remove contact from reject list, by mistake in put one contact in rejct contact
