Brookstone (467522) Clock Radio Logo
Posted on Nov 20, 2010
I recently purchased #4521 SKU#634014 It's worked great but I somehow messed up the time and now can't find the manual to fix it. A simple question...how do I set the time? The alarm setting isn't a problem. Thank you.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 29, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
663
Points
Why won't tv turn on by remote or power button unless we try 4-5 times?
My TV has the same problem.
At first, it was an issue with the button itself, somehow some gunk got down under the button and kept it from pressing down all the way most of the time.
A few days after we fixed that, it started to mess up again, this time it was an issue with the way it transmitted signal to the TV.
If the button being blocked isn't the issue, replace the batteries. If the batteries aren't the issue and you don't have a soldering gun, then you'll need to purchase a new remote.
I bought one from walmart for ten dollars and it works just fine for basic use.
I have a 1979 CJ 7 that I just recently purchased. The turn signals dont work. When I hit the brakes the turn signal ligts light up on the speedometer.
I suggest you do the simple low $ things first..Replace the bulbs (sometimes a filament can break and cross over to another inside a bulb)
Replace the flasher unit. Make sure all socket grounds are good.
If that does not help, likely the problem is in the turn signal switch inside the column under the steering wheel. (get a haynes or chilton manual for dis-assembly instructions)...it isn't difficult to do but too long to write here.
Unless it's obvious that someone messed with the wiring, chances are it is OK.
Jamming, roller lines and loud fan
You'll want to purchase the service manual for this printer if you do not already have one. Obviously the fan is the most annoying problem. But the jamming, the roller marks, and other issues would indicate that the entire printer is probably needing to be cleaned out and that the rollers may even need to be reconditioned or replaced.
2answers
No heat - Kenmore - model 75811
Correct - it is that simple. I just went through the same thing - not even 15 minutes ago. And, they are basically linear motor fields. The drive the cylinder (post they slip over) out, opening the valve, allowing gas flow.
http://fixitnow.com/2004/11/appliance-repair-revelation-burner.htm
My convergence is offline
the convergence needs to be adjusted for 480i then also enter into the 1080i and adjusted for that format. You would need the service manual for the parameters or you could severely mess your set up. You can purchase the full service manual for your set and get it emailed to you instantly by going to this link, they also offer free tech assistance if you have any difficulty when you purchase a manual. Here is the link.
http://servicemanuals.vstore.ca/
4helpful
4answers
Trying to send photo from my samsung SGH-u600
Thank you VERY much!!
I even downloaded the user manual from the web,hoping it might provide more in-depth info. than it has in the little booklet that comes with the camera,only to find it was exactly the same thing online!
I was getting pretty worried,thinking I'd somehow messed up the photo-sending imaging,as up until today it was working fine!
I've just gone through the process as you suggested on Aug.18th and it is going great once more--I just hope it stays that way,lol!
Thank you again! xxxx--K
My DVD recorder won't play my CDs
Recently purchased a unit... You can imagine the joy when I found in Manual: Audio discs can only play if in .mpg or .wma formats! Yes, all the bells and whistles except the most basic of functions such as all common audio formats. Other portable $99 dvd player works with them.
Top Brookstone Audio Players & Recorders Experts
 Grubhead
Grubhead
john h
Are you a Brookstone Audio Player and Recorder Expert? Answer questions, earn points and help others
