When toilet is flushed the toilet slowly drains its water from the bowl and refills only a small amount...it seems like there is no pressure to pull the contents of the bowl into the pipes...the water mechanism in the back of the toilet works properly but the tank also refills slowly
Re: When toilet is flushed the toilet slowly drains its...
First thing is to take a wire coat hanger and clean out the grit and grime out of the ports under the rim these always need to be kept open or they will restrict the proper amount of water needed to flush the contents away. then try it with some toilet paper and see if this didn't fix your problem.
Water will pull from your toilet if you drain below your toilet is slightly blocked. Most drains in the USA are about 4 inches wide and will allow quite a large amount of waste to pass through. Any blockage will force more pressure from the drain to the toilet and pull more water from the bowl. Reversed effect you will get bubbles that push through to the inside of your toilet. might try some toilet waste line dissolving cleaner..
Hope this helps FixYa issue - Have a great night..
The included link should provide some help in determining your specific design. Depending on your specific design the flapper is a critical component in controlling the amount of water released from the tank during flush.
The appearance of water flushing is in fact created by the siphon action of the water falling down through the drain pipe.
Any restriction in the down stream drain flow can give the appearance of a bad flush. So the problem may not be flush, but a restriction in the drain pipe, or trap-way or outlet.
Using a bucket filled with water pour water quickly into bowl and observe the flush action. Compare the action with another toilet using the bucket. If the flush appears adequate and the water from the tank flows slowly check for salt buildup at the nozzle end of the outlet from the tank into the bowl.
In the design below there is a transfer tube that injects air into the trap. This provides a vacuum to promote the siphon during flush. A leak or failed seal in this transfer tube would result in poor flush.
If drains are slow, particularly if you hear a "gurgling" sound at fixtures during draining, I'd suspect that the building vent system is blocked restricted. A restricted drain is much more likely than a restricted vent. Small children are likely to have placed non biodegradable toys etc into the toilet and they may have gotten trapped. Build up in the vent pipe is also common.
In this example ice is blocking the vent!
Pressure assisted toilets have a stainless steel tank that refills under lid,if your refilling bowl it only needs to fill trap for smell,the pressure assist does the rest,thats part of the water saving of the toilet,you don't have a lot of water in the bowl
Sounds like you have a clogged drainline or vent-stack. Fill a large bucket with about three gallons of water and dump it quickly into the bowl. If the drainline/vent is clear, the toilet will "flush" like a gravity toilet and the water will drain from the bowl almost as fast as you can pour it in.
If the water level in the bowl slowly rises (as if it's about to overflow) and then slowly drains, you have a clog somewhere.
All toilets, regardless of their flushing mechanism, require a clear, unoibstructed drain/waste/vent system to extract waste.
If the toilet "flushes" with the bucket of water, you may want to call Flushmate tech support (the number is on top of the tank) or check out the installation and troubleshooting videos at howto.flushmate.com.
Check to be sure small tube is flowing inside the ovefow tube. This is the water that flushes the rim holes, and refills the bowl. If you don't have flow clean or replace the float valve.
Unless the water is running out onto the floor, the ONLY place it can go is into the toilet bowl. The amount of water in the bowl (known as the "water spot" - which is a reference to the size of the surface of the water) can be no greater than what the geometry of the bowl and trap will allow. Unless the trap is clogged, the height of the water spot is determined by the trap. Some newer toilets have a pretty small water spot. To confirm the size of your water spot, very slowly pour water into the bowl from a bucket.
Is it not refilling the tank or the bowl? I've got a toto also that is not fully refilling the bowl after each flush. No leaks or other problems. Tank refills fine. Seems that the flapper doesn't float long enough to allow a sufficient amount of water to drain into the bowl before closing. Any ideas?
First, fyi, adjusting the knob? in the tank, or the fill level will not increase the amount of water in the bowl. The bowl fills to a certain point, and then as more water is added it starts to go over the built in trap, and down the drain. When you flush the toilet, all the water in the tank dumps into the bowl, and the existing water is pushed over the trap and down the drain. All of this being said it sounds like you may either have an internal crack, between the bowl and trap; you may have a crack that is draining under your toilet, (water spots?), or you have a more serious plumbing issue, improper venting, which is causing a vacuum, and pulling the water out. Hope this helps.
