I was wondering if i use this recovery cd-rom that came with my cyberpower pc if it will erase my connections on my router and modem with my time warner cable internet ? which means ill have to have a member from time warner install it back up again?
Its a windows 7, and my files are corrupted soo i need to do with disc
Are you using windows XP or Vista. You should not have a problem if after you do a full system recovery, you add any service pack updates. Download these first and burn to a disk. Also make sure that all the drivers get reinstalled ok. After doing the recovery go into system device manager to see if your network card is installed even if it is a internal one on your motherboard.
If your connection is wireless you may need to setup a wired connection first from the router.
Time warner roadrunner usually works right away with little problems.
Well i am using xp , i never recovered or formatted a pc b4 so idk how to do this sorry , lol so i put in the cd im trying to write all my info ima need and programs ill need later so when i recover it ill redownload them but so i put the cd in and just recover?
its a windows 7, and my files are corrupted soo i need to do with disc
