I want to replace the electronic control board (part #8302319) on double oven model GBD277PDS10. I've order the part. The power is off and have taken the right and left trim strips off and have removed the 4 screws from the front trim. I cannot remove this front trim and cannot access the control board.
How do I remove the trim around the display window and access the control board?
Thank you!
I have a Whirlpool RBD275PRT00 that showed the same codes. it would allow me to cancel and work for a few more days until the display finally went blank and after a few days of being blank displayed the codes again. I ordered a New Electronic control board from Sears W10340941 for 189 dollars just recently, when I just looked for this part for your model it's that same number but now listed for 254. There are services that will repair your board for a little less but it will not be a new board. it's still much cheaper that a new oven.
E2 F6 means that your oven temperature sensor has failed as well your electronic control board.
The oven temp sensor, electronic control board and the touchpad must be replaced. Before you decide what to do, check the thermal fuse at the control panel first. If blown, replace it and the temp sensor.
If you are lucky the control board may still be good.
ggg1234~
I don't have a solution unfortunately, but I'm having the same problem. I had someone come out to look at it and they said that part #W10244191 was a mistake b/c of the larger slot and Whirlpool hasn't started production on correcting this problem... nice,eh?! I think this is a Whirlppol problem and they need to do something about it, and quick!
Hello, Getting beeps when you push the keypad buttons means that power is getting to the control board. First, try shutting off the breaker to power down the oven for a few minutes, then turn back on. This will force a system reset, hopefully the oven will recover.
If not, you probably have a problem in the control board. If this is the case we may be able to save you some money if you can get the board pulled. We repair oven controllers at www.fixyourboard.com
On this model, F03 indicates a faulty power control board (also known as the "Capricorn" board by Whirlpool technicians). A new oven with no guarantee? There is usually a reason something has no guarantee, in your case, a faulty control board. It is a relatively expensive part unfortunately.
You can try disconnecting from power, removing top panel from oven. The large square electronic board you see on the top of oven is the power control board. Check all plug connections are OK, especially the large thin multi plug that goes to the display board- I have had a poor connection at this plug causes F03 faults. If still no go, power control board will need replacing
More
then likely your electronic clock control board is going bad. After turning the power off, you can also try cleaning the connectors on the clock board and make sure the connectors are tight.
Hi there, Well, F7 error code occures due to A = Function pad button stuck or B = Bad clock Unstick button or Replace Electronic Range Control (ERC)
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver. REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order. Best of luck!! Thanks
