Watches Logo
Posted on Nov 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I set the date on this watch. Can set the month, day and time but not the date.
Anonymous
Level 3:
Genius:
  • Master 1,970 Answers
  • Posted on Nov 19, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1970
Questions
0
Helped
847291
Points
4702
Mcdevito75 here, You may have to go thru the entire 24 hour cycle to change the date, then re-set month and day. Depending on what kind of watch you have.
How do I set the day & date on my Timex Indiglo watch?
Google shows how.
https://www.leaf.tv/articles/how-to-set-the-date-for-a-timex-expedition-indiglo-watch/
?Quoting from the link above:
?"The Timex Expedition Indiglo wristwatch tells the time and date, illuminates at the press of a button, and can wake you up at a designated time. Once you receive and adjust your watch to your liking, you might have questions about how to program the date properly. You’ll want to have an accurate watch before wearing and relying on it throughout your day in class, at work or while exercising. You can set the date on your watch with a few simple steps.
Pull the plastic guard from beneath the crown knob (located on the right edge of the watch), and push the crown knob into the watch to start your watch. You will see the second hand begin to advance.
Pull the crown knob out to the middle position to set the day. The crown knob has three positions: “In,” “Middle” and “Out.” Turn the crown knob clockwise to advance the days up, until the current day appears in the window on the right side of the watch face. Turn the knob counterclockwise to move the date down in number. Push the crown knob all the way in to start the watch.
Pull the crown knob completely out, if the day doesn’t change with the knob in the middle position, and cycle the time backward or forward through 24-hour periods until you arrive at the current day. Push the knob in to start the watch.
Pull the crown out to the middle position and adjust your date to the next month for months that have less than 30 days. Your watch will cycle through 31 days every month, so manual adjustments for shorter months are required."
tip
HOW TO SET DAY / DATE ON AN ANALOG (STEM) WATCH
mcdevito75 here, Over Forty (40) years ago, watch manufactures added, to some of their ANALOG (wind up) and almost all of their DIGITAL (button display) watches the FEATURE of the, MONTH or DAY of the WEEK and the DATE, not only was the time of day available but also the DATE which you no longer had to go searching for, it was readily available on your wrist. The PROBLEM came with SETTING the CORRECT MONTH or DAY of the week and the DATE as some MONTHS HAD 31 DAYS rather than 30 DAYS, this meant you had to CYCLE your watch at least 62 times to get to the CORRECT DATE and mant times, when you finally did reach the CORRECT DATE, the day of the week was off, meaning more CYCLES thru the 24 hours.-------- HERE is the EASY way to SET the MONTH or DAY / DATE on your QUARTZ / MECHANICAL (STEM) watch without haveing to go thru the 24 hour cycle so many, many times. Not only is this, WEAR on your fingers, you can also damage your watch with some many cycles of the 24 hours to SET the correct MONTH or DAY / DATE. ------ HERE ARE THE BASICS,---------- Your ANALOG or STEM watch either QUARTZ or MECHANICAL should have a TWO (2) position STEM we are only familiar with the ONE (1) position we use to set the TIME, there should be TWO (2) positions to the STEM. First pull out the STEM to adjust the MONTH or DAY depending on your watches display, if your watch DISPLAYs the DAY of the week, set the DAY to one (1) DAY before the DAY you want, don"t worry about the DATE (number) yet. Once you have the MONTH or DAY set, push the STEM back into the watch, NOW with a finger nail just under the STEM (usually from the back of the stem as there is more room) gently lift the STEM to it"s first position, It may take some practice so be patient, once the STEM is in it"s first position you should be able to turn the STEM to adjust the DATE (number), if so Adust the DATE (number) to ONE (1) DATE before the DATE you want, This way your watch will be adjusted to change the DAY / DATE at the correct time. Once you have the DATE (number) adjusted to ONE (1) DATE before the DATE you want, push the STEM back into the watch, NOW pull the STEM out to adjust the time, go thru the 24 hour cycle to adjust to the correct DAY DATE (number) and time of day.------------ Your QUARTZ or MECHANICAL (stem) watch is now adjusted to the correct DAY / DATE and will change at the correct hour which is generally 12--1 AM.
on Jul 20, 2010 • Watches
tip
on Jul 09, 2010 • Watches
My timex 1440 sport watch has buttons that are slightly different than any manuel I can find on line. the buttons are as follows going clock wise from top left mode, stop/start,adjust,and indiglo. I just...
Try this:
To set time and date:
1) With time and date showing, press SET.
2) Seconds ?ash. Press START/STOP to round time to nearest minute,
setting seconds to zero.
3) Press MODE. Hour ?ashes. Press START/STOP to change hour,
including AM (no symbol) and PM.
4) Press MODE. Minutes ?ash. Press START/STOP to change minutes;
hold button to scan values.
5) Press MODE. Month ?ashes. Press START/STOP to change month.
6) Press MODE. Date ?ashes. Press START/STOP to change date.
7) Press MODE. Day ?ashes. Press START/STOP to change day.
8) Press MODE. Time format ?ashes. Press START/STOP to select
12- or 24-hour time format. 12-hour format has AM/PM.
9) Press SET, at any step, to exit and save settings.
Date (day of month) appears in upper part of display in Time mode.
Press and hold START/STOP to see month and date in large digits.
How do you set the day and month?
Mcdevito75 here, The stem on your Timex shou;ld have two (2) positions, slip a finger nail just under the crown and gently lift to the first position, it may take a little practice to get but you will. In this first position you"ll see by turning the crown one way you can change the date (number) and turning in the other direction you can change the month or day, if so, set the day and date to one (1) day before the day and date you want. Push the stem back in and lift the stem all the way to set the time of day, now cycle thru the watches 24 hours to set the day and date you want. Your Timex is now set and will change at the proper time of around midnite. If your Timex has the month and day you may have to cycle the 24 hours to reach the correct month other than that these instructions should help.
8helpful
How do you set this watch....4 buttons
SETTING THE TIME AND DATE ON AN OLD 4 BUTTON DIGITAL WATCH
[L1] [R1]
[L2] [R2]
SETTING THE TIME.
Press [L2] to move through the modes. When the time display flashes, you are in the correct mode to set the time. The hours first, then the minutes and seconds.
Press [R1] to advance the numbers, [R2] to go to the next.
Press [L2] to save your settings. [L1] is not used; it's the light.
SETTING THE DATE AND DAY. After setting the time (seconds flashing) push [R2] to move though time, backwards, to date, [R1] to set day, [R2] to move to month [R1] to set the month. Push [R2] to get to the day of the week, then [R1] to change. [L2] to end.
2helpful
Pulsar watch, how do you set the day of the week and month?
mcdevito75 here, The stem has 2 positions, first adjust the day or month by going thru the 24 hour cycle with the stem. once set, slip a finger nail just ubder the stem and lift carefully this should allow you to change the DATE adjust to 1 date before the date you need, now pull the stem out to adjust date and time of day turn sten the complete 24 hour cycle to achieve the correct date and time of day. Now your watches day and date are set and will change to the next day date on time, around Mid nite 1 --2 AM.
How to set dates, etc.
mcdevito75 here, The stem should be 2 position, first pull the stem out to adjust the DAY ot Month, push the stem back in, now slip a fingernail just under the stem anf lift to the stems first position, this should allow you to change the DATE, adjust to 1 day before the DATE you need, now lift the stem to adjust the time, go thru the complete 24 hour cycle to adjust the DATE and time of day. You should have the DAY or Month and correct date and your watch will change the DAY, DATE at the proper time also.
2helpful
2answers
Setting month, date, and day of the week on non-digital watch
Try pulling the stem out. Turn the stem in the counter clock wise direction and see if that changes the date/day
Dec 21, 2008 • Watches
Date and month
There are three positions when you unscrew the crown stem. One does the day, one does the date and one does the time. You can also advance the date by rotating the crown stem and advance the time for 24 hours, as if a day passed. That takes a lot longer.
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
