Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer Logo
Posted on Nov 19, 2010
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Dec 02, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
8759
Points
5
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
http://www.scribd.com/doc/34420420/Buzzer-Disconnect-Frigid-a-Ire-Gallery
How do I disable the buzzer on a Frigidaire Gallery Series Washer
Hey friend, thank you for your post!
I understand that you would like to disable the buzzer for your Frigidaire washer. Typically the buzzer cannot be disabled within your Frigidaire washer. If you have any additional questions please feel free to reconnect. -Matt
Frigidaire stackable washer making loud clunking noise when spinning
You will need to take the front cover off and check to see if there is anything lodged between the drum and housing.
Hello, I have just purchased a frigidaire gallery series stackable combo 2004 model glet1142cso after hooking it up i am having problems. It won't fill unless dryer door is open..won't spin out...
Probably an auto tec installed the recepticle on the wall or in the electric pannel. in home electric the black wire and the red wires are hot. In automobiles the black is ground. You should have 240 volts between the two flat connectors on the plug when its pluged into the recepticle.
I have a stackable Frigidaire Gallery Dryer. It won't turn on...
turn the start and it's like the drum gets stuck. then starts smelling like burning.
3helpful
I have a Frigidaire Gallery Stackable that has a screechy dryer
Sounds like it is worn out. Get a parts diagram and take it apart and see what parts are missing or worn out. The belt is probably coming apart and that is the black stuff. There are several plastic wear plates and a bearing/bushing for the drum, plus the belt idler and all these can wear out. The motor could also have a bad bushing in it but more than likely that will require a new motor as they don't usually sell just the bushing or end caps.
Sounds like the bearing is gone, call a repiar man or buy new as repairman 100 per call
10helpful
4answers
Kenmore stackable washer dryer. Dryer buzzer is
Just solved this problem for a Kenmore stackable washer dyer! Sorry I don't have the model number. I have a baby on the way and a small house. I was pretty sure I would get no sleep between the baby crying and the baby crying because of that darn buzzer!
The buzzer is attached to the timer with a quick connect post. Access the controls by unscrewing the large panel above the washer door. You will need a square screwdriver or a very small flathead and some vice grips to get it started. The panel will fall forward onto the washer. In mine there was a pouch with an electrical diagram of the unit. To release the controls, two more screws must be removed from the sides of the small panel housing the controls. Once again you need a square screwdriver or a very small flathead and some vice grips to get it started. Once these are out you should be able to lift the control panel up and it will fall forward. Get a small box or stand to put on the washer. This will support the panel as the wires are not that long. On the left side of the timer controls you will see a quick connect post marked with an "H". Disconnect this wire and your problems are solved. Beautiful silence! I put electrical tape on the quick connect wire. Not sure if I needed to as I'm not an electrician. Hope this helps.
Apr 09, 2009 • Dryers
9helpful
2answers
Turn off buzzers
I had the same problem and the buzzer was one of the worst sounds ive heard. But, I found the buzzer and turned it off for good. Open the front panel and look for a small part in between the 2 main curcuit boxes.I have a Fridgidare stackable combo FLEB8200FSO. On mine this small part is number 144547100. Look for two black wires, one goes to H and the other to C. Disconnect both wires and no more buzzer!! Good Luck
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
