Televison & Video Logo
Posted on Nov 19, 2010
What is the uverse remote code for a vizio M190va tv
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
915
Points
Can I use your remote universal Llz414
Wholesale VIZIO DPS-200PP-190 2950318703 POWER SUPPLY UNIT ,cheap price ,and orginal board ,good quality
https://www.abctay.com/vizio-dps200pp190-2950318703-power-supply-unit-p-1644.html
Att remote to vizio tv codes?
AT&T remote control have no set-up code for Vizio..
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
1helpful
Can i turn my vizio m190va tv into a computer monitor?
Unfortunately. the HDMI port on the M190VA does not interpret the signal from a computer. The HDMI signal from a set-top box is different than that of a computer. You need to use the VGA port and the PC audio in on the TV; if your computer doesn't have a VGA port, use a DVI to VGA adapter or other appropriate adapter. You will need a 3.5 mm audio patch cable to use the TV's speakers. See page 25 of the M190VA manual here: http://store.vizio.com/documents/downloads/hdtv/M190VA/364User%20Manual.pdf .
I wish that I had better news for you.
6helpful
What is the remote control code for vizio
Unfortunately, there is not just one code I can give you. I can give you a list of codes that work with all Vizio TV's, so one of these will work. It will just be a little trial and error.
2-Digit remote Codes
19
3-Digit Remote Codes
502
627
004
113
505
011
4-Digit Remote Codes
1758
0178
1756
0128
0117
1017
1078
0030
0056
0205
1292
1004 (Works Mainly with Uverse)
5-Digit Remote Codes
10178
10117
11756
11758
01377
10885
10864
10120
1helpful
2answers
Need a code for att uverse for the remote for vizio lcd
Click Here for the list of Manufacturer's Code for AT&T Uverse
3helpful
3answers
I am trying to program my vizio remote to work with my uverse box. would you know the code? other ways around it??
Vizio Television 1343, 1018, 1004, 0178, 0502, 0627, 1756, 1758, 0128, 0117, 1017, 1078, 0030, 0056 VIZIO HDTV 1004
If your tv is HD mute wont work.
This is for programming the uverse remote to the vizo tv. From my understanding the uverse box doesn't have a code.
23helpful
4answers
Not able to program vizio remote towork with att uverse Cisco box
Maybe too late for you but ATT just gave me a code that works with my Vizio plasma. Code is 1343. Even the mute works correctly. They gave me some others to try but I didn't need them. Other codes were 1018, 0030 and 0056.
1helpful
2answers
UVERSE REMOTE CAN NOT TURN OFF VIZIO 42' TV
The documentation that came with my U-Verse equipment doesn't list Vizio products, but I have been using 1343 which I saw suggested on another website. AT&T's support site has a new code list (http://www.att.com/support_media/images/pdf/uverse/set-up-code-list.pdf) showing Vizio under the TV section as 1489 and in the HDTV section as 1429, 1433, or 1439.
None of the codes listed for Vizio work with my Vizio LCD(model VO370M), but the 1343 code I've been using successfully is listed in the new list as an LG HDTV code.
2answers
Tv code for uverse remote
THRER IS NO CODE THAT WILL WORK WITH THAT MODEL I EVEN CALLED SYLVANIA AND THEY TOLD ME THERE ARE NONE
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
