Question about One For All URC-3021 Remote Control
I have a viore tv dvd combo need codes for it
    New Friend:
You probably have the same problem that I found after I'd purchased my Viore TV (LC 26VF59), your cable box remote or dish network remote doesn't have the Viore codes built in. Bummer. I looked around and couldn't find codes for my Viore. Doubt you'll find them for yours. Here's a helpful suggestion I read about that works for me:
I bought for $20.00 a Sony RM-VL600 Easy Learn remote control from my electronics store. It's EZ because you only have to place the Sony head to head with the Viore remote, press TV setup and follow Sony's instructions to have its remote catch and learn the codes from your Viore remote. I only programmed my Sony for the Power On/Off, Vol Up/Down from my Viore remote. You back out of Setup and now your Sony will control the TV for those functions. Next you get your cable box or satellite remote put it head to head with the Sony remote, press the CABLE or SATELLITE set-up button on the Sony and then have it learn all the C or S functions you want from that remote. You do program in this mode the Power On/Off button, but you don't program the Vol Up/Down. The volume for the TV will work when you're all finished and operating under the Cable or Satellite button on the Sony remote.
Now, you press the TV button on the Sony and then the Power button. The TV turns on. Now you press the Cable or Sat button and then the Power button and the Cable or Sat box turns on. Like I said, even though now you are operating the Sony remote under the Cable or Sat button the TV volume instructions carry over to this side of the remote so you don't have to switch back to the TV button to raise or lower volume of the TV.
When I'm done watching, I hit the Power off and the cable box turns off. I then hit the TV button and again the Power off button and the TV turns off. So, it's a little inconvenient when starting and stopping, but at least you are using only one remote.
Hope this has helped.
Posted on Dec 17, 2010
3 Suggested Answers
Anonymous
SOURCE:
Anonymous
  • 4 Answers
SOURCE: Need code for Emerson TV,DVD,VCR Combo
I don't have a code book for you, but I can tell you how to program the RCR660 using the automatic programming feature.
Programming RCA model RCR660 (no code search button)
While following these instructions, keep the following in mind:
device = the component you wish to control with your remote (TV, DVD, VCR, etc.)
DEVICE = the button labeled for the component you wish to program
1. Turn on the device you wish to program.
2. Turn off all other devices in the general vicinity.
2. Press and hold DEVICE
3. While holding DEVICE down, press ON/OFF and hold them both down until the LED turns on for that device.
4. Release both buttons.
5. Point the remote at the device, press and release PLAY and wait 5 seconds or until the LED stops flashing.
6. If the device does not turn off, then continue to press PLAY and wait the required interval (for a maximum of 20 times) until the device turns off.
7. When the device turns off, press REVERSE, wait two seconds and continue doing this until the device turns back on.
8. To finish programming, press and hold STOP until the LED turns off.
Posted on Dec 31, 2007
Anonymous
  • 74 Answers
You may be able to get the codes here free:
http://www.replacementremotes.com/tvcodes/index.html
Posted on Mar 25, 2008
Where's the Manul for RC2011V TV for Viore TV for my tv?
The RC2011V remote came with several different Viore TV models, including the LCD22VH56. Manuals Lib has the manual for this TV here: https://www.manualslib.com/manual/511216/Viore-Lcd22vh56.html . The remote is described on page 10; the link to that page is https://www.manualslib.com/manual/511216/Viore-Lcd22vh56.html?page=11#manual . Additional information on using the remote with the built-in DVD player on this TV is in the DVD section. This starts on page 15, https://www.manualslib.com/manual/511216/Viore-Lcd22vh56.html?page=16#manual .
I hope this helps.
Nov 12, 2017 | Viore Televison & Video
I need a code for a 26 in viore tv/dvd combo
For which remote exactly? Each manufacturer of programmable/learning remotes has their own code base and unique numbers for each code.
Asking for a code is like asking for the postcode/zip code of Acacia Avenue but without specifying the city and district.
Sep 07, 2014 | Viore Televison & Video
I have a viore tv dvd combo wont play dvds says no signal
If won't play DVD, DVD is not working and should be repaired, if possible. Take it to an authorized repair shop
Jul 07, 2014 | One For All URC-3021 Remote Control
Need Viore code for ATT-U-Verse remote.
I tried every code suggested for my Viore with Uverse and nothing worked. Finally decided to reset the remote to factory settings using code 900 as described in the instructions from ATT uverse. The remote now works on my Viore tv and all I did was reset the remote to factory settings.
May 17, 2010 | Toymax Viore 42 in. Plasma TV
My daughters viore 21 inch dvd combo wont read dvd's
The fact that you are hearing a squeaking noise means it's a mechanical defect. The drawer belt is a likely culprit in this case. Unless you are familiar with electro-mechanical systems it's unlikely that you can fix it at home. For the least expensive fix you need to purchase another external DVD player and hook that to the audio video INPUTS on the back of the set.
You might try a local repair shop for an estimate on your product.
Apr 16, 2010 | Televison & Video
Voire lcd20v31 tv dvd combo
Wow - unbelievable - they should be sued. I just bought a floor model that had been returned. The returnee did not return the remote or the manual, so it appeared to be a great buy. Now i believe they bought it purposely for the purpose of taking out the remote and manual and then returning the pc for a refund. Got on here and saw your post, because we too could not find a remote that would work on this tv/vcr combo. - RIDICULOUS!!!
Jan 30, 2009 | Akai Televison & Video
Need code for Viore TV to program LG RC897T DVD/VHS Recorder
I believe Viore is the same as Samsung. I only noticed this by accident as I bought a Viore TV and my friend bought a Samsung and I noticed both remotes were identical. I tried the Samsung codes and the remote worked. Good luck! Kevin
Dec 29, 2008 | LG RC897T DVD Recorder/VCR Combo
One For All URC-3021 Remote Control Logo
1,184 people viewed this question
Top One For All Televison & Video Experts
Christopher Stearns
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
