Question about Toshiba Satellite P205-S6287 Notebook PC
DELL xps touchpad
I bought a dell xps 1330 3 months back .The dell touch pad is not working.When i cheched in the device manager i found under mouse it is giving message "This device is not present, is not working properly, or does not have all its drivers installed. (Code 24)"
The touch pad icon is not coming in the system tray as well.
Please help....
    New Friend:
    Problem Solver:
  • 6 Answers
1.This might be due to incorrect touchpad settings or corrupted touchpad drivers.
I recommend you to try the steps in the below link which may fix the issue:
http://laptoptouchpadnotworking-fix.com/?p=1
Posted on Jun 11, 2012
    Genius:
  • 2,028 Answers
Sounds like a driver glitch, from the device manager, try uninstalling it, then do a hardware search, it will locate it and reinstall the drivers automatically. If this doesn't solve the issue, then the touch pad has failed and needs replacing.
Posted on Jun 20, 2008
6ya staff
SOURCE:
Hi i have Dell XPS laptop...USB mouse not working
Make sure you have the correct driver downloaded.
Dec 18, 2009 | Dell U0636 Mouse
HOW TO DISABLE TOUCH PAD DELL LAPTOP
You should have a "FN" key on the keyboard and one of the "F" keys should have a symbol that looks like the touch-pad, hold FN while using this key should disable it, failing this in control panel, then mouse and pointers, you should have touchpad setting there should be a disable button/radius.
Sep 04, 2009 | Dell Inspiron XPS M140 Notebook
XPS 1330 screen turns black
My first guess is that your video card is starting to go bad. My second guess is the processor needs to have its heatsink reseated. If it is under warranty I would have dell repair it so you don't incur the charge of a new video card.
Jun 16, 2009 | Dell XPS M1330 Notebook
I have a dell xps 1330 and the touch pad stopped working abruptly. Now there is an icon that looks like a note pad and pen to the center left of the display. What did I do, and how can I get the touchpad...
had a similar problem on a laptop i was working on - the touchpad quit immediately after an update.
try using an external USB mouse and then reinstall the driver for it - that's what fixed it for me.
Jan 15, 2009 | Dell Inspiron 6400 Notebook
Philips PA1039 Wireless mouse and Dell XPS laptop
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Jan 01, 2009 | Philips PA1039 Mouse
Dell XPS 1330 touchpad scroll areas quit working
Hi Patrick,
The most likely problem is that the ribbon cable from the touch pad is not making proper connection with the motherboard.
I would recommend you get this repaired under warranty, there is a bit of work involved in pulling the laptop apart to get to this cable & connector and if you do something wrong it could void your warranty.
I can give you instructions if you wish to try and fix it yourself.
Let me know.
Nov 26, 2008 | Dell XPS M1330 Laptop
Touchpad/mouse problem
Same thing here, I can not find out how to diable the touch paid. I spent an hour chatting on-line with Dell Tech support and they did nothing to help!! I am starting to think it can not be done on this machine. Please someone tell use how to do this?
Jul 10, 2008 | Dell F3534 Touchpad
Touch pad
HI,
The xps 1330 is known to have problems with the internal speakers. Kindly call Dell Tech support and get the same replaced,while your system is under warranty. The cable that connects the speakers inside is either not connected right or is broken. If you are geeting sound form the headphones , your soundcard is fine , and there is no software problem on the system.
Thanks
mandeep
Jun 09, 2008 | Dell XPS M1330 Laptop
At&t Wireless Air card
did your air card come with drivers and did you do the network setup wizzard for wireless connections
was this the floor model or boxed
did you flip the anttenna up to activate card
This phone can only be used with a compatible service plan.
is your service setup cause that would explain alot your comp needs a phone number for the card
May 10, 2008 | Dell Inspiron XPS M1710 Notebook
Toshiba Satellite P205-S6287 Notebook PC Logo
390 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
