Posted on Nov 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WHEN PRINTING BLACK AND WHITE DOCUMENT, HALF THE PAGE PRINTS FINE THEN BLOCKS OF WRITING ARE BARELY VISIBLE. THE BOTTOM HALF OF THE SENTENCE PRINTS BUT THE UPPER HALF DOES NOT LOOKS STREAKY.
Anonymous
Level 3:
  • Master 386 Answers
  • Posted on Nov 19, 2010
Anonymous
Master
Level 3:
Answers
386
Questions
0
Helped
130322
Points
1549
Hi Good day!! Try to clean your print head, go to printer and faxes and then right click your installed printer and then properties go to Maintenance menu and then click on Head Cleaning and Alignment.
Thank you for using FixYa
Don't forget to vote thanks
Some pages offset printing
You need the paper feed tires replaced.
Canon pixma iP1000 is skipping random lines when printing
Sounds like it's congealed ink on the print head. You can buy cleaning kits and do it your self. Relatively in expensive compared to leaving it into the shop.
Problem with printing in black writing not clear and very faded.
It sounds like you need to run a printhead cleaning. The print head is what you put the ink cartridges into, it's responsible for placing ink directly to the page. If the some of the nozzles are clogged up, it can give you bad print quality. Without knowing the exact model of your printer, I can't tell you exactly where to find the menus needed to run the cleaning. Sometimes you can do this via the "maintenance" tab in the printers properties. If you need any further assistance, feel free to let me know.
3helpful
Bottom of letters in document not printing.
it is problem your printer page setup please set defalt or re install printer driver
thanks
xptareq
2answers
Bottom of page is cut off sometimes printing from vista computer
Are you useing vista print drivers for the vista computers or are they XP drivers?
Black and white not printing correctly, color is fine
If you are not using Epson ink, your printer will do this. Epson printers hate knock-off ink. Always use Epson ink if you want to keep your printer working properly. To solve the problem you are having, try cleaning the ink tubes. Make sure you re-install them properly. Hope this helps. Charlene
Printing
try to do a system restore to a date when it was working ok, if still no go, then reinstall the printer driver.
Wont print
some printers share the ink from color to black but you can select if you wants to use only black just go to printer than properies than select to use only black but you probably have to remove the empty color one
My ip90 Canon printer only prints in purple
Try selecting an option in the printing properties to print in grayscale or black and white (you usually only have either one or the other). This will utilise ONLY the black cartridge, the color will remain dormant which should make your prints come out in black and white - if not, your black cartridge, or the space between the bottom of the black cartridge and the paper is contaminated with color ink. Good luck!
k24674
ADMIN Andrew
ADMIN Andrew
