Erasing all files in a
folder
You can delete all files in a specific
folder by the following steps:
1. Turn on the unit.
2. Select a folder (A/B/C/D).
3. In Stop mode, press FORWARD
continuously until “ALL” appears on
the display.
4. Press ERASE and “DELETE” will
blink on the display.
5. Press and hold ERASE for about 3
seconds, all files in the selected folder
will be erased completely (or press
STOP to cancel erasing all files).
Go to RCA web site, find support or download or alike. If you can find the exact model, download one or two similar then read those similar features. Try and error. that's how I got my RP5017 work
Turn on = Play + Menu (at the same time) Turn off = Stop (will revert to just clock) Selecting folders or changing options = Turn on then press menu to move through options and use the forward and backward buttons to change within options Deleting a file within a folder = Select the folder through menu options (A or B) then exit menu (cycle through all options or press stop once while in menu) then press the forward key to cycle through files within folders (1 or 2) then press delete once to display "Del" next to file then press delete a second time to delete file. Take batteries out to quickly reset recorder (will not lose saved files)
1. Select folder (A/B/C/D)
2. Select file.
3. Press ERASE once and DELETE will
blink on the screen.
4. Press and hold ERASE for 3 seconds
to confirm deleting. (or press STOP to
cancel erasing file)
