You can increase the ringer volume from the menu ... by the way Uniden DECT 6.0 Cordless phone basically have very low ring volume ,,, try using an extra ringer which is very cheap or you can make your self ... A simple circuit diagram available on http://www.electronics2day.com/index_files/Page790.htm
SOURCE: My son turned off the ringer on our uniden
Pick up the handset and underneath the handset is an off on switch for the ringer
Handset ringer switch
This switch turns the handset
ringer on or off.
Page 20 of the manual
EXAI985HS
English
2,578 kB
Product Details
SOURCE: uniden 2.4Ghz
You can get the manual on the Uniden web site. Here is a link to the page for cordless phone manuals. Just look for your model # and click it. It will then open a pdf format of the Owners Manual.
http://www.uniden.com/index/manuals_results.cfm?cat=1
SOURCE: ringer on
Here is a link to the Tru8885 manual:
http://www.uniden.com/pdf/TRU8885om.pdf
Rollin CBs
Dean
SOURCE: how do you adjust volume on base ringer on uniden dxa15588-2
Setting the Main Base Ringer Volume
The main base has three ringer volume settings: high, low, and off. You can change
the ringer volume while in standby mode or while an incoming call is ringing.
1) Press the ringer key.
You hear the ringer at the current volume level
([ ] High, [ ] Low, [ ] off) (if you set the
main base ringer volume to off, “Ringer off” is
announced) and it is displayed on the main base.
2) Press the ringer key repeatedly until the desired ringer
option appears.
3) The system displays the new ringer volume.
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
