Dell 922 All-In-One InkJet Printer Logo
Posted on Nov 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I get this printer to operate with a Windows 7 PC?
George Mclaughlin
Level 2:
Sergeant:
  • Expert 372 Answers
  • Posted on Nov 17, 2010
George Mclaughlin
Expert
Level 2:
Sergeant:
Answers
372
Questions
Helped
128168
Points
839
Go to www.dell.com . Type your model number into the search window in the top right corner. This opens up the pages pertaining to your dell 922 all in one. Click on " help and support". The 7th article on the list should help you. Operating system compatibility with Dell printers. Hope this helped you.
Steve Allison
Level 3:
  • Dell Master 5,569 Answers
Steve Allison
Dell Master
Level 3:
Answers
5569
Questions
Helped
2000802
Points
16452
Check the Dell support site; you may need a new driver. Most companies do support their products with updated drivers for several years after production has ended.
My printer does not work with windows 7 ultimate
You need to go to the printer manufacturer website and download the Windows 7 drivers for your printer.
tip
Computer Drivers for Windows 7 & Vista
Most printers that were made before 1997 will not operate on the Vista & Windows 7 operating system. If you browse around different search engines you will find some companies that updates some printers to operate on the newer versions of Windows. Of course they will have a charge for this update although the cost is far less than purchasing a new printer for most of you
on Jul 29, 2010 • Computers & Internet
2answers
Previous use window xp recently have one note book window 7 our printer is not working window 7 processing the method of driver installed
My dear friend, observe computer peripherals compatibility. If you are telling that your printer is working on windows xp that means the printer designed only for windows xp but some printer right now is supported with different operating system. Anyway download a printer driver for windows 7 if it has and install the software first and plug the printer after installing the software. Have a nice day!
I need to make functional my epson stylus cx4100 scanner under windows 7 operating system
Hello - Have you actually tried installing the all in one printer? According to Microsoft "This product installs automatically without extra software."
If you have plugged it into your Windows 7 PC and it was recognized but is not working I suggest you remove the printer from Windows 7 ("Start menu" then "Device and Printers" then right click on the printer and select "Remove device."
Epson created Windows 7 drivers are available at their website HERE as are printer and software user manuals.
Good Luck and Thanks for using Fix Ya.
Mikeywaf
2helpful
My HP laser jet P1005 cannot install with ACER Aspire windows 7 system but can install with another pc Vista system. why ? please help me, thanks
To instal HP Laserjet P1005 Printer on you Aspire System with Windows 7, you need to install Windows 7 drivers for HP P1005. Click here to go to HP Official and download Windows 7 Drivers for HP P1005. Select the Operating System (e.g. Windows 7 32-Bit)
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Trying to install software for x4270 into new machine with Windows 7. Tells me software not available in English. Was previously installed with XP in old machine with no problems. Any ideas?
Uninstall the existing Lexmark X4270 printer driver from your Windows 7 by going the Start menu ? Programs ? Lexmark 4200 Series ? Tools ? Uninstall. Reboot pc when prompted. When pc turns on, check if your Windows 7 is running on 32-bit or 64-bit operating system by going to the Start menu ? right-click on Computer ? click on Properties. Take note of the system type.
Download and install the X4270 driver for Windows 7 using the links below:
Follow the instructions in the software.
Thanks.
2answers
Is this printer compatible with Windows 7 insalled in a computer
HP PSC 2210 Printer is compatible with windows 7 operating system. You need to install the windows 7 compatible drivers from this link selecting your operating system.
Hope this helps.
Best wishes.
Can't connect printer.
Hi, It seems that the you might have upgraded your computer to Windows 7 and you are not able to get your printer work. In this case you need to download printer's driver for the operating system that you are using that is Windows 7 64-bit. Download the driver from: http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-DX5000-all-in-one-printer/Drivers-Support
Once downloaded, install the printer using the new obtained driver. Hope the new driver would work on your computer. Moreover, you may change the USB port to which the printer is connected, meaning unplug the printer from the computer and re-connect it to different USB port of your computer and try to install printer.
Cheers!
I have one computer which operating system is windows vista home premium. Another PC with operating system Windows 7 Home premium and have set up to share one HP K80 Printer. Now problem I believe is the...
Instal only one printer driver on the PC it is physically connected to. Preferably the Windows 7 PC (Latest OS). Unshare the printer, remove drivers from other PC's., then reboot al PC,s and re-share the printer. The PC's sharing should allow the Windows 7 PC to use it's driver, although they may request a disc for basic information about the printer.
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
